10-11-2008, 07:04 AM | #1 |
Newbie Join Date: Oct 2008 Location: South Africa
| cr-01 top heavy
hy all ! i feel that the cr01 is a bit on the high side so iets keeps on faling over if i go onto steep inclines... so what can i do to get some weight on the wheels or what do you suggest ? thanx guys |
10-11-2008, 07:27 AM | #2 |
RCC Addict Join Date: Sep 2008 Location: Philadelphia, PA
Weight in the wheels Lighter battery Smaller battery Thicker shock oil to dampen excess movement Use the bigger stabilizer bars and firmer springs to keep the top end from wanting to lean over on side hills. Although this will degrade your suspension articulation elsewhere. On inclines where youre going forward up the hill firmer springs in the rear will help the rig from going over backwards. So will more weight in the front wheels than in back. Overall, I've learned to drive extremely slow in off camber situations. Last edited by 860Crawler; 10-11-2008 at 07:29 AM. |
10-11-2008, 01:53 PM | #3 |
RCC Addict Join Date: Feb 2008 Location: tauranga north island new zealand
Hey its scale,you get your 1;1 4wd with as much torque on the same angles and it will roll or flip as well!.
10-11-2008, 03:00 PM | #4 |
Pebble Pounder Join Date: Nov 2007 Location: Chubbuck
Mine is also top heavy but I added more wait to the wheels and lowered the bettery |
10-14-2008, 04:56 AM | #5 |
Rock Crawler Join Date: Jan 2008 Location: Eveleth
I run about 4oz in all the wheels and flat irons. The flatter tire along with the extra weight has helped. If you change your shocks out and lose the cantis that will help too....
10-14-2008, 03:25 PM | #6 |
Newbie Join Date: Jul 2008 Location: Westminster
I moved the battery tray and electronics tray forward as far as I could and lowered the battery tray as much as I could. I am running a small 3s lipo pack. I mounted the lower back links in the back hole on the frame and also moved the transmission forward on the skid. I am also running 60 wt shock oil and the stiffer springs in the back. This has made a big difference in how it handles hills. I am climbing stuff I would of never figured I would before. RM "Do not take life too seriously...You will not get out alive!" Last edited by StarOne; 10-14-2008 at 09:29 PM. Reason: fixing typo |
10-14-2008, 05:10 PM | #7 | |
Rock Stacker Join Date: May 2008 Location: Cupertino
How do you go downhill with this setup? Rear in? Quote:
10-14-2008, 09:27 PM | #8 |
