cr01, droop i got my cr01 that i traded for my nitro bronco today. it came with two bodies the fj and a blazer. i'm down with the blazer even though its in rough shape... i will be adding more trail damage to it soon. (dents) after changing out the 75 turn motor i found the tranny had a bind issue. i searched on here and found that a few people had plastic flashing that wasnt allowing bearings and such to be seated proprerly. that was my case today as i had to rebuild the tranny. after that i took it out for a rip around the yard and noticed quite a bit of slop with the stock cantilever suspension. after toying around for a while i decided to run my aluminum bodied tmaxx shocks setup in droop. body on shots... http://i34.tinypic.com/23ifqc6.jpg http://i37.tinypic.com/2hmljyc.jpg rear shocks minus cantilever junk and monkey barrel springs... http://i37.tinypic.com/29m93c5.jpg front end... no more junk... http://i38.tinypic.com/2w2o9oj.jpg body off shot http://i37.tinypic.com/14ty9sg.jpg now my only concern is i didnt have the small springs to put inside the shocks yet, as i wasnt sure if i was going to have it sprung, ( it looked like a swamp truck ) or keep it drooped. does it make a big difference if the springs are not in the shocks ? what have you done to clean up the cantilever pile ? |
woke up this morning and took it for a short trail run. i noticed that the shaft angle was a bit tough and i was getting a binding issue at the top of the suspension travel due to the 3 racing bent links in the front. :roll: i tried every config there was with the bent links in front and decided it was better off that i make my own straight links for the front end. also i found the reason for putting the small springs inside. now i just need to find what size. "thumbsup" |
went to home depot, and found some spings that might work, took them home... no good. too much tension. then i looked in my pen holder and found 4 matching pens. doh ! works great. "thumbsup" |
It looks great! What size are your shocks?? |
looks good. glad to see people starting to rip off that junky looking cant. system. since i like to run drop on my comp rigs, i would suggest losing the bent links if you want to run droop. i have always had better luck with straight bottom links on a droop set-up.... |
i have axed the bottom bent links in the front, i just haven't gotten around to doing the back. thanks for the compliment, it's a fun truck to drive now. before i couldnt deal with the all the slop it had, and to me it had too much articulation for a trail beater if that sounds right "thumbsup" actually i did add that trail damage too... look here.. http://www.rccrawler.com/forum/tamiya-cr-01/145267-lil-burb-trail-beater.html |
You guys all inspire me. I have a cr 01 Bronco coming in Thursday. I already have a ton of changes I want to do to it as I am building it!!!"thumbsup" Thanks:mrgreen: Norm! |
