Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Tamiya Scale Rock Crawlers > Tamiya CR-01
Thread: Iwantoffroad's CR-01
Old 12-06-2008, 11:55 PM   #1
Cool Iwantoffroad's CR-01
Here is my new Tamiya CR-01 Land Cruiser
Specs
Suspension
springs swapped front and rear
no front sway bar
hard sway bar in the back
front shocks
2 holes in the piston 25 weight team associated silicone shock oil
rear shocks
3 holes in the piston 40 weight team associated silicone shock oil
Properly assembled shocks and they haven't leaked yet.
EeePee's rear shock mount idea
Drivetrain
front drive shaft spacer
front drive shaft extra male piece added
Spacers under rear upper links mount on the axle
ball bearings re lubed
all drive train components lithium grease
0.25 degree clocked rear axle
locked axles
stock motor broken in, with water
wheels and tires
foam for the tires trimmed
stick on weight added to the front and rear rims
Electornics
stock motor
Hitec servo Hs-625
Tamiya esc Teu-101bk
Tamiya rx Tru-02
Misc
cleaned up wiring
built with loctite as instructed
foam body mounts
Servo horn protection
different clips for the battery tray
iwantoffroad is offline   Reply With Quote
Old 12-07-2008, 12:20 AM   #2
that thing looks clean
sounds like you spent a little bit of time putting it together the right way.
good job !
crunky is online now   Reply With Quote
Old 12-07-2008, 07:57 AM   #3
MODERATOR™
EeePee's Avatar
Just what I was thinking. Nice post too.
EeePee is offline   Reply With Quote
Old 12-07-2008, 10:41 AM   #4
Finish the grille,good build.
vipxj is offline   Reply With Quote
Old 12-07-2008, 09:29 PM   #5
good job !
Thanks crunky
I take pride in my builds, I also take them slow and enjoy the build.
Thanks EeePee
In the past I have built most of my rigs in stock form,
then later started to mod them. But on this build,
I wanted to do as many tweaks that I could find
while I built it.
I have always liked to have a well documented build
thread for all of my rc cars and trucks. And a very
methodical procedure in doing so. Also taking many
pictures along the way.
Thanks Vipxj
The reason why I haven't put the grill on yet is
because I haven't decided if I want to paint black
or leave it stock silver.
After today I decided on leaving it stock silver
for a classic look.
Old 12-08-2008, 07:17 AM   #6
awesome
860Crawler is offline   Reply With Quote
Old 12-08-2008, 10:40 AM   #7
Yeah ,silver is good,and have fun with it.
Old 12-10-2008, 12:46 PM   #8
Originally Posted by 860Crawler View Post
awesome
Thanks
Ya im going with silver
Old 12-10-2008, 12:53 PM   #9
I went to a little gtg last weekend and took some pictures
Enjoy
Old 12-10-2008, 02:35 PM   #10
That location looks pretty cool. Did they just dump excess concrete over the rocks there?
Old 12-10-2008, 05:40 PM   #11
im acctually not sure but it does look that way doesn't it.
Its my local crawling site so I'm not complaining
Old 12-11-2008, 03:15 PM   #12
Bok
nice rig how's the teu-101bk holding up? i tried it on mine but it would get really hot after a while so i took it out.
Bok is offline   Reply With Quote
Old 12-11-2008, 08:54 PM   #13
Yes it gets pretty hott only if i keep it at full throttle all the time. If I'm just messing around its fine.
I have blown up a few of these esc's thou, so be careful
Thanks
I put it temporarily just to test the truck out.
Hopefully I will get a new esc for my comp rig for Xmas and the esc in my comp rig will go into my CR01
Old 12-16-2008, 03:51 PM   #14
Is this the regular silver can that's overheating the TEU?
hamnet is offline   Reply With Quote
Old 12-27-2008, 07:04 PM   #15
its loading the motor up by trying to go over obstacles or full throttle for long periods of time.
that causes tge teu esc to overheat
Old 12-27-2008, 07:24 PM   #16
Great pics!
I'm runnin the stock silver can with a Novak Rooster, I have'nt had any over heat issues yet with this setup.
HDMM is offline   Reply With Quote
Old 12-29-2008, 08:22 PM   #17
nice
i have the rooster in my other crawler.
No complaints about it.
Old 01-01-2009, 11:37 PM   #18
updated thread.
Iwantoffroad's CR-01 axial plates and droop setup
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
