01-01-2009, 04:08 PM | #1 |
Rock Crawler Join Date: Sep 2004 Location: South Orange County
| Iwantoffroad's CR-01 axial plates and droop setup
Hey guys this was my original build up Iwantoffroad's CR-01 And this is LifeRacer's idea. I am taking no credit for it. I just liked his idea and improved upon it. CR-01 with Axial Chassi Plates Here is my new and improved Tamiya CR-01 Specs Suspension front shocks 2 holes in the piston 25 weight team associated silicone shock oil going to put pen springs and fuel tubing soon. rear shocks 3 holes in the piston 40 weight team associated silicone shock oil going to put pen springs and fuel tubing soon. Spacers under rear upper links mount on the axle rear upper links mounted outermost rear hole. Inboard mounted lower links Drive train Front drive shaft splined 2 male 1 female. ball bearings re lubed all drive train components lithium grease 15 degree clocked rear axle 25 degree clocked rear axle locked axles stock motor broken in, with water Wheels and Tires and Steering foam for the tires trimmed stick on weight added to the front and rear rims tie rod mounted in front of the axle. drag link mounted behind the axle for a BTA hybrid setup. Electronics stock motor Hitec servo Hs-625 Tamiya esc Teu-101bk Tamiya rx Tru-02 Misc built with loctite as instructed foam body mounts Servo horn protection tlt servo plate used for a battery mount. left to do determine what shock oil viscosity to use. determine what shock piston to use. buy a smaller battery Thanks to PinchFlat for hooking me up with two axial chassis plates for free mock up electronics mock up 4 link esc mount front I wanted to make a strut brace to tie in both shocks to keep the chassis plates from flexing incorporate a body post mount because I hate side body post mounts. a place to mount the esc and a place to mount the antenna the mount is made out of a credit card cut up and the mount is supported on all sides. and at the angle its at it will not interfere with the movement nor the cycling of the suspension nor the 4 link. body mounts are from team associated rear body for the tc3 part number 8874 strut for the shocks traxxas turnbuckle part number #2339 back rx mount a servo post tlt cantilever rod tlt servo plate cut up to fit the rx. this creates a mount for the rx it limits the battery from coming to far into the chassis, it prevents the battery from hitting the motor,drive shaft, rx, wiring, and upper link. Last edited by iwantoffroad; 01-14-2009 at 07:26 PM. |
01-01-2009, 06:33 PM | #2 |
RCC Addict Join Date: Sep 2008 Location: Philadelphia, PA
At least cutting up the credit card will slow down your spending Nice work! |
01-01-2009, 08:06 PM | #3 |
Say hello to my dactylion Join Date: Jun 2004 Location: On the Boat to Whore Island
Nice... I like what you have done with all this.
01-01-2009, 08:27 PM | #4 | |
yep so its win win for me. light weight and less spending. PinchFlat Well worth the effort, and thanks for help. | |
01-02-2009, 02:30 PM | #5 |
Rock Crawler Join Date: Feb 2007 Location: Peoria, Arizona
If it will fit you should try moving the tie rod to the back of the steering knuckles for quick BTA. thats the setup I've got going on on my drooped CR-01 and I like the steering much better. Ackerman angle seems much better, i.e. the inside tire turns sharper than the outside tire. my dropped and drooped CR-01 |
01-02-2009, 03:33 PM | #6 |
thanks for the tip i will try to see if the tie rod will fit behind the axle. did you fit yours above or below the knuckles I could not really tell by the pictures. |
01-02-2009, 06:03 PM | #7 |
Nice work, do you have any pics with the fj body on it? how much did the wb change? i am really tempted on doing this to my cr-01 since i have 2 extra ax-10 chassis plates.
01-02-2009, 07:58 PM | #8 |
Pebble Pounder Join Date: Dec 2007 Location: CA
How do you mods. the skid plate ? The CR's one or the other ?
01-03-2009, 12:19 AM | #9 | ||
I tried to fit behind the axle but you would need a spacer on each side and it would need to be on the inner hole on the knuckle. How did you mount yours? Is it on the inner or outer hole? Did you have to bend the tie rod at all to fit around the drive shaft? http://www.scale4x4rc.org/forums/sho...285#post379285 Quote:
I dont have any pictures with the fj body I dont plan on using the fj body on this rig, thats why I don't have any pictures. The stock CR-01 wheelbase is to long for the stock tamiya fj cruiser body if I were to shorten the wheelbase the body would be perfect. the wheelbase changed a little bit in my opinion but only a bit longer. its right at about 11.5inch. I don't rember the stock wheelbase figure but you can measure that. Can you rephrase that question. I used the stock CR-01 and drilled holes in the stock axial plates. It fits perfect. I hope I answered your question. Last edited by iwantoffroad; 01-03-2009 at 03:55 AM. | ||
01-03-2009, 09:12 AM | #10 | |
the third picture on the thread below shows some detail of the BTA: http://www.scale4x4rc.org/forums/sho...140#post331140 Last edited by lowslowTJ; 01-03-2009 at 09:26 AM. Reason: details | |
01-04-2009, 05:43 AM | #11 |
I have a BTA setup. thanks lowslowTJ It should work great. Last edited by iwantoffroad; 01-04-2009 at 10:31 PM. |
01-04-2009, 10:58 PM | #12 |
Just about done. At full droop the driveshaft splines were barely engaged so i build a longer driveshaft. Here is the before shot. What I'm going to use. Done. And there is no binding and it can reach full droop and still be completely engaged. lowslowTJ gave me the idea to run a BTA setup. I tried it out and it was a tight fit but with a spacer it worked out great. I found a fuel tubing and pen spring combination that I like. I might cut the tubing a bit more and switch to a 1 hole piston and bump it up to 70 weight oil. full flex. needs improvement. |
01-05-2009, 02:57 PM | #13 |
Rock Stacker Join Date: May 2008 Location: los angeles
This is looking great, pal |
01-05-2009, 03:18 PM | #14 |
Quarry Creeper Join Date: Aug 2008 Location: UK
I second that. The bug looks really good on it.
01-05-2009, 03:43 PM | #15 |
01-05-2009, 03:47 PM | #16 |
01-05-2009, 05:12 PM | #17 |
yes it does. I would like to try out aluminum knuckles to see if the knuckles would move less under stress. |
01-05-2009, 05:46 PM | #18 |
01-06-2009, 02:57 AM | #19 |
that would be nice. a great comprise of great steering and added strength. I went to one of the comp sites I go to. I went over to the cdm spot at sunset tonight. It was awesome. |
01-08-2009, 11:49 AM | #20 |
Ohhh that positive Ackerman angle looks great!
