02-10-2009, 06:27 PM | #1 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
| A couple of new mods for my CR-01
It's been a little while since I've done anything with my CR-01 besides drive it since I installed the Junfac heavy duty steering links. I picked up some cool parts and finally had a chance to install them. I bought a set of the Pro-line bumpers, roof rack, light bar, and scale accesories. First I installed the roof rack, and light bar, they top off the Land Cruiser body nicely. Next, I wanted to do the front bumper, the Pro-line front bumper was just too big and it did'nt look right on the Land Cruiser, so I used the rear bumper for the front. I cut the CR-01 front bumper mounts and made a mounting bracket from angle aluminum stock. Once I got it the size I wanted, I drilled holes to mount the Pro-line bumper to my bracket, painted it and installed the bumper. I also installed the Jun Fac driveshafts, these are awesome, they are heavy duty and fit great! I also installed the Jun Fac straight axle adpators. Again, heavy duty parts, well made, great fit. I also upgraded the tires to 2.2 Mudslingers mounted on Pro-line Eight Shooters. I put 3 ounces of weight on the inside of each front wheel and two ounces on the rear wheels. That should help keep this thing on it wheels instead of on it's roof. The next thing I'm doing is changing ou the stock silver can for the Tamiya CR-Tuned 35t motor (waiting for it to come in the mail) and I am going to lower the body a little more to get it to look a little more scale. I also plan to make a rear bumper, probably out of aluminum channel. |
02-11-2009, 06:17 AM | #2 |
Quarry Creeper Join Date: May 2005 Location: Crossville,TN
Actually, I think your bumper modification came out very good. And the work you did to make it fit was great. Good job! Carl |
02-11-2009, 11:56 AM | #3 |
Quarry Creeper Join Date: Sep 2008 Location: South Glens Falls
Awesome job you did on your rig!! The JunFac shafts do look great. Look to be great quality units indeed.
02-11-2009, 06:01 PM | #4 |
The Jun Fac shafts are great, I ran the truck today with no problems. You can't beat the price for stainless steel driveshafts!!!
02-16-2009, 02:23 PM | #5 |
Quarry Creeper Join Date: Jan 2004
You can go wrong with Junfac stuff!! Everything I ever bought from them has been great fit and finish!! Your CR01 looks great, I like how the rear bumper looks on the front of the FJ40 .....Tom |
02-16-2009, 04:45 PM | #6 |
RCC Addict Join Date: Jan 2009 Location: ?????
could you still use the stock rims with those straight axle adapters? great lookng rig!! |
02-16-2009, 05:05 PM | #7 |
I have the same set of straight axle adapters and the OEM wheels work great. They just make the rear end look so clean. My only mod would be to have them black anodized. Carl |
02-16-2009, 05:25 PM | #8 |
| sweet, ima have to get me a pair!! i cant seem to get the rear measurements right and the tires have a bit of an angle to them, these look like they will eliminate that problem |
02-17-2009, 10:45 AM | #9 |
Newbie Join Date: Jun 2005 Location: Fairfield (Cordelia Hills)
The straight axle adapters make the rear axles look super beefy.
02-27-2009, 05:23 AM | #10 |
| You could also paint them, I used a Marine paint called Trilux, it is actually a antifouling paint, but it is made for aluminum outdrives and lower unit on outboard motors. I used that paint to paint my aluminum bumper bracket, the stuff is very durable and sticks to the aluminum better then regular paint.
02-28-2009, 05:40 AM | #11 |
Pebble Pounder Join Date: Jan 2009 Location: Planet Earth
One suggestion to make it perfect, do something to the frame. Paint it black, powder coat it, anodize it, or spray it with bedliner. Think of what a real frame on one of these trucks would look like.
02-28-2009, 07:30 AM | #12 |
I wanna be Dave Join Date: Jul 2008 Location: appleton
nice work like the axle shafts and light bar nice looking rig
03-01-2009, 10:21 AM | #13 |
Rock Stacker Join Date: Jan 2009 Location: british columbia
awesome rig dude and nice color |
