03-22-2009, 09:57 PM | #1 |
Newbie Join Date: Mar 2009 Location: saugus
| free play in drive line
So I just installed the tamiya diff lock set up along with tamiya steel drive lines. What I don't remember is the small amount of free play that I can feel starting with the tires. If I grab the tire and move it back and forth I see the drive shaft move so I think the free play is just small amounts through out each point that is adding up to what I'm feeling. Is this normal? Hope this is making sense. Thanks |
03-23-2009, 12:35 AM | #2 |
Rock Stacker Join Date: Dec 2008 Location: Australia
Absolutely. After all it's a Tamiya. That being said it is a good idea to make sure you have the bevel gear mesh set up correctly and shimmed if necessary.
03-23-2009, 01:44 AM | #3 |
Newbie Join Date: Mar 2009 Location: Belmont
I also agree, there is a little play in mine--the more moving parts you have, the more play you will have. |
04-03-2009, 09:56 PM | #4 |
tamiya's drive shafts have always sucked for me i broke the 1 in my cc-01 with just a 27 turn axial motor
04-19-2009, 08:00 PM | #5 |
Pebble Pounder Join Date: Jan 2009 Location: Planet Earth
I have this same problem with both my CR-01 and my AX10. There are eight or nine points where a small amount of slack can occur. The more time that goes along, the more play will develope. I would make sure your driveshaft screws are tightened down. My AX10 has about 150 or so runs on it since I bought it. Just from normal friction and wear and tear, there is enough slack that if you hold the rear wheels, you can turn the front wheel about twenty degrees. Thats two years of driving though...
