04-07-2009, 11:53 AM | #1 |
Rock Stacker Join Date: May 2008 Location: seattle
| Wheel Offset
Hey guys I was curious if you would be able to use the DNA bead locks that have the ax10 offset? I am not sure what the CR-01's offset is but i really like those beadlocks so....... any help would be great!
04-08-2009, 05:56 AM | #2 |
Rock Stacker Join Date: Oct 2008 Location: Fairmont
Yes, you should be able to run the DNA beadlocks with an axial offset. Im running a newer style axial beadlock on my CR01 now. Hope that helps.
04-09-2009, 12:19 AM | #3 |
Pebble Pounder Join Date: Apr 2008 Location: yakima
i had a set of axial wheels on mine for a little bit and that made the truck much wider. it will work though
