05-09-2009, 02:44 AM | #1 |
Pebble Pounder Join Date: Mar 2009 Location: Las Vegas
| mud and water runners .. help!
What are you guys doing about rusting bearings? Is there a water safe bearing out there ? It seems like that's the last thing I need to do to waterproof my CR, but I haven't seen anything. Time to tear it apart, it's been sounding sick, like sick in a bad way, not gangsta lingo |
05-09-2009, 05:47 AM | #2 |
RCC Addict Join Date: Sep 2007 Location: Westland, MI
WD40 and pack the axles with grease.
05-09-2009, 03:47 PM | #3 |
simple enough, thanks! I'll do that first when I tear it down in the next few days. any water resistant or sealed bearings available tho? |
05-09-2009, 05:33 PM | #4 |
Rock Crawler Join Date: Jul 2007 Location: Rectalville
Yes, there are sealed bearings available, but "sealed" is a relative term here. Roughly 3x the cost of regular bearings, and the seals WILL eventually fail from exposure to dirt/debris/mud/etc. and you'll be in the same boat again... it'll just take longer... All I do is spray my rig down with WD-40 before any water-or-mud-involved run... And I mean the WHOLE rig, except the body... makes the muck come off easier... Then once you get home, hose 'er off and spray it with the WD-40 again immediately following that... The WD-40 will dis-place the moisture from the bearings. I've been running un-sealed bearings now for over 2 yrs and only had to replace 1 so far... and my Scaler sees plenty of the wet stuff. |
05-10-2009, 01:49 AM | #5 |
ok, sounds good, thanks for the tips guys can wd40 revive my rusty bearings or do I need new ones now that they've rusted ? |
05-10-2009, 06:40 AM | #6 |
Rock Stacker Join Date: Mar 2009 Location: charleston
| bearings
I use wd-40 when they start sounding rough...
05-11-2009, 06:30 PM | #7 |
Rock Stacker Join Date: Dec 2008 Location: Australia
The key is to make sure it is clean before you put it away. X9 WD-40 |
