Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Tamiya Scale Rock Crawlers > Tamiya CR-01
Thread: CR-01 Yota LC40 by carlos46 from CZE
Old 02-27-2010, 01:58 PM   #41
Really nice build! Just read it through. I like your cage. I'm thinking of making a simple cage from brass tube. Did you use ordinary solder and an iron? Do you need a torch to heat up the tube?
eemmaaxxxx is offline   Reply With Quote
Old 02-28-2010, 03:00 AM   #42
I work with manual gas burner.
carlos46 is offline   Reply With Quote
Old 03-11-2010, 10:05 AM   #43
Little update...
(inspiration from Diagoro - thanx man )
After
Before
Offroad capabilities are maintained.
And chassie
Old 04-01-2010, 06:28 AM   #44
Toyota got a spare wheel on rear door, some logos and also hand made snorkel.
Old 11-10-2010, 12:37 AM   #45
I recently saw some pictures of the Arctic trucks.
So I bought new fenders and wheels used an old 2,2 that I had.
Old 11-10-2010, 08:00 PM   #46
so sick! love those crazy arctic trucks. well done!
cydog510 is offline   Reply With Quote
Old 04-15-2011, 11:57 AM   #47
Ok. After the bodies of 2x Toyota FJ40, Ford Bronco, Toyota HDJ80 came the next new :-)
Old 04-15-2011, 12:26 PM   #48
Looks like a fun project. I really liked the 80 series, so much so that I ended up buying one. I think I'm going to put it on a SCX10 chassis though.
DRW-FJ40 is offline   Reply With Quote
Old 04-18-2011, 01:55 AM   #49
looking forward to seeing the mog body on the dropped chassis rails. i am sure it will look more realistic. i have seen others drop the flat bed in this body to create a useable pick-up type bed, might be an idea.... keep us updated carlos!
Old 04-19-2011, 02:54 AM   #50
So, I completed my Mog. Unfortunately, lowering the chassis is so large and had a total body go a little higher than I wanted. With a full reduction of sticky round of wheel arches and a cross is in that case the minimum:-(
Old 04-19-2011, 03:15 AM   #51
OK.
I found the original image on the net and my modified Tamiya Mog reduced chassis.
On the two cars look the same. My, unlike the original, and about an 0,78 inch of gravity. Therefore, this should have a better stability in the field.
Old 04-19-2011, 07:55 PM   #52
looks good! would love to see some pics on full articulation.
Old 04-20-2011, 01:44 PM   #53
Hi,
wow nice surprise, you found my mog (the orange)
its not realy originaly, its almost fully costumized and i mounted the 3racing high clearance knuckels
because them looks very high.
Nice work on your CR-01, good idea with the Dampers inside
Good work and go ahead
Antholzer is offline   Reply With Quote
Old 04-20-2011, 07:46 PM   #54
Just finished this reading this post and wow what a cool project with lots of optional bodies!
I wish I had your free time and money!
cr01 is offline   Reply With Quote
Old 04-22-2011, 02:10 AM   #55
Thanks Antholzer,
your Mog looks very good.
I now, i'm waiting for a new wheels of JunFac.
Old 04-27-2011, 01:56 PM   #56
New beadlock wheels from JunFac are great. Have a little more than offset the original Tamiya, but that's all right.
Old 10-10-2011, 06:43 PM   #57
Great build(s)... I'm still partial to the white orig FJ. I saw that right before I was going to the paint store tomorrow.
You are using zero shocks from junfac, no? What length? Also you had PL Chisel tires, correct? Finally were you using the stock foams that came with the chisels? Thanks!!!
SpeedVision is offline   Reply With Quote
Old 10-11-2011, 12:25 AM   #58
White FJ is already past. Shocks are JunFac. I think the length is104mm. Although producers wrote that they are directly for the CR-01, but they are too long. Less would definitely have been better. Proline Chisel is great, but the FJ body too big.
Old 10-11-2011, 05:04 AM   #59
Thanks. I'm just starting out so we'll see where I end up. It's all fun!
Old 11-13-2011, 04:46 AM   #60
So after some time I decided to re-re-remake of my CR-01.
I was inspired by the user of French farfab :-)
thanks man
The work goes slowly, because I have little time, but maybe I make a it to spring.
And that's how it could look like in the future somehow
To be continued
