06-16-2009, 01:15 PM | #1 |
Newbie Join Date: Feb 2009 Location: cape breton canada
| cr-01 build
Just recently built a tamiya cr-01,when i push the truck on the floor manually, it will not freely roll on it's own. there is no electronics asside from the motor installed, is this normal? I don't want to burn out the motor or speed control, any help would be appreciated.
06-16-2009, 01:26 PM | #2 |
Rock Stacker Join Date: Feb 2009 Location: Northern
Mine was the same way, it was my tranny not put together exactly even try reassembling it.
06-16-2009, 01:54 PM | #3 |
Rock Stacker Join Date: Feb 2009 Location: rockland maine
make sure your axles were done right i had to swich my rear around cause they were fighting one was going back and one was going faward
06-16-2009, 02:27 PM | #4 |
Rock Crawler Join Date: Jul 2008 Location: Port Angeles
Yes it's normal, you're fighting the magnets in the motor. Take the motor out and then see what it does.
06-16-2009, 03:33 PM | #5 |
RCC Addict Join Date: Jan 2009 Location: ?????
it could also be that the pinion and spur gear arent meshed properly. .. . that was my problem. .. . |
06-18-2009, 01:25 PM | #6 |
Newbie Join Date: May 2009 Location: Rockford
Definately check the spur and pinion mesh. If its even just a little too tight, it will make the driveline incredibly hard to turn over.
