09-01-2009, 12:50 PM | #1 |
Pebble Pounder Join Date: Oct 2006 Location: Leaving black marks on Hwy 200
| My conclusion on switching over to springs from cantilever
After crawling with some friends I realized that their Axails were lower to the ground and had better stability on side hills and up hills. My CR-01 was extar top heavy wasn't very sure footed. My original articulation was nice but it was worth giving some. In the end I lost about 1/2" ground clearance and some articulation(not too much)but I think it was well worth it to get more stability in the other areas. I also weighted my front wheels and pulled the foam out.
09-01-2009, 04:31 PM | #2 |
I wanna be Dave Join Date: Aug 2008 Location: cape crud... will you be my friend
pics or it didnt happen |
09-01-2009, 09:41 PM | #3 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
| Ahhh, I thought you were over there checking out my tires a bit to much!!! yeah man, lets see pics...so I take it you put shocks on it?? you know looking at your chassis (first time I saw a CR01) it needs a different chassis for sure...lots of weight. was a good time, now....on with the pics..... we'll wait.. |
09-02-2009, 08:41 AM | #4 |
RCC Addict Join Date: Sep 2008 Location: Philadelphia, PA
wow, no foams, what does the tire look like now? Must look like you riding on 5 psi. You still might need some support, don't the tires just fold over now on side hills?
09-13-2009, 04:41 PM | #5 |
RCC Addict Join Date: May 2008 Location: Southern,WV
| I took my cantilevers off all together.And replaced the white springs with a set of black springs from the front shock off a rustler. And no shocks. Works well for me. |
09-13-2009, 05:19 PM | #6 |
Rock Crawler Join Date: Sep 2008 Location: Delta B.C.
this works pretty good.. i left the rear cant assembly in for the swaybar..works pretty good for what it is..a big heavy traibasher |
09-14-2009, 08:15 AM | #7 |
Looks like it sees some nice trails
09-14-2009, 06:29 PM | #8 |
sure does..no shortage of rocks and trails here |
10-28-2009, 12:28 AM | #9 |
Newbie Join Date: May 2008 Location: denver
how much weight is appropriate in wheels anyways?
11-01-2009, 06:36 AM | #10 |
Newbie Join Date: Oct 2009 Location: Gilford
11-08-2009, 10:26 PM | #11 |
Quarry Creeper Join Date: Jun 2009 Location: Way down under!!!
Weight is a good qu? Also, what thickness are your shock spacers? They're sitting nicely almost vertical, does it affect your articulation at all? |
11-09-2009, 01:22 AM | #12 |
in my trailrigs i dont run much wieght 3-4 oz or even none..in a crawling rig 6-8 oz..per front wheel the spacers are 3mm or maybee 1/8th'..it still articulates enough, pretty good aqctually..its a trailrig so not really looking for crawler type articulation |
11-09-2009, 01:27 PM | #13 |
I put 9oz in each front and it was too front heavy, if I stopped on a steep downhill climb it would nearly go end over so I added 6oz to each rear and its fine now.
11-09-2009, 07:48 PM | #14 |
Thx, Im running unweighted at the moment, will be adding strip lead as soon as I can motivate myself to pull the wheels down. |
