10-18-2009, 08:21 AM | #1 |
Rock Crawler Join Date: Apr 2008 Location: Greentown
| how much can the CR-01 drive train hold?
Hey guys I want to make a rock racer/go fun rc. Prolly be on a 35T motor with a side winder ESC on a 3S lipo. Can the CR-01 drive train hold that? I know the SCX can but IMO the CR-01 is way cooler and I like the tamiya kits I put together in the past. Thanks guys!
10-18-2009, 10:43 AM | #2 |
RCC Addict Join Date: Sep 2008 Location: Philadelphia, PA
Just upgrade the driveshafts to steel and it will be pretty bulletproof
10-18-2009, 01:44 PM | #3 |
What would you recommend?
10-18-2009, 05:29 PM | #4 |
rc4wd punisher shafts would be an excellent upgrade and will hold up to anything up can put to them. bit pricey though
10-18-2009, 06:44 PM | #5 |
Quarry Creeper Join Date: Jun 2009 Location: Way down under!!!
GPM shafts are a well built, cheaper steel option.
10-18-2009, 06:51 PM | #6 |
Thanks for the tips guys! Going to start saving ;)
10-19-2009, 04:16 AM | #7 |
Quarry Creeper Join Date: Dec 2004 Location: Croydon, Surrey, UK
Junfac shafts are about $30 for the pair
10-19-2009, 02:46 PM | #8 |
Quarry Creeper Join Date: Aug 2008 Location: UK
JunFac are the best ones I've found for the CR-01. 3Racing ones are alright, but ugly blue. Avoid the following: RC4WD Punishers. Very solid, and I'm sure they're good for long-reach crawlers, but the design means they bind easily on shorter rigs like the CR-01. HotRacing ones. They require a very small allen key which strips easily rendering the shafts useless. |
10-19-2009, 02:49 PM | #9 |
Thanks for the heads up fatwoul! |
10-19-2009, 06:07 PM | #10 |
those are also good options but another would be traxxas metal yokes and a 6 pack of shafts and i have punishers on my cr01 and have had no binding issues with them ever |
10-19-2009, 10:21 PM | #11 |
Quarry Creeper Join Date: Aug 2008 Location: San Jose
just my 2cents... it is better to snap the drive shafts because they are plastic rather than breaking/stripping the gears inside the axles because the steel shafts were stronger than gears much easier to replace the drive shafts than breaking open the axles to replace the gears. i run HH7T cobalt puller with 3S and have not snapped a traxxas stampede shaft yet. i easily snapped the stock CR01 drive shafts on the stock motor with 3S (and I burned up the stock can too because of the 3S!!). |
10-20-2009, 06:40 AM | #12 |
Newbie Join Date: Aug 2008 Location: Czech Republic
I had JunFac shafts and I can say that its not good choice.
10-20-2009, 01:48 PM | #13 |
Rock Crawler Join Date: Nov 2004 Location: in a basement in Kalispell, MT
Center drivelines for a tmaxx are 5mm. Little work and they are a great plastic upgrade and cheap. More than a year and I'm still on my first set.
10-20-2009, 02:07 PM | #14 |
thanks for all the different options guys! I can get t-maxx shafts for cheap, but may just get Junfac and be done with it.
10-20-2009, 02:13 PM | #15 |
just throw it in and snap the stockers for easy removeal! id suggest traxxas or the junfac shafts for the cr-01 Last edited by 2500hdon37s; 10-22-2009 at 07:50 AM. |
10-20-2009, 03:01 PM | #16 |
If you can strip a gear inside the axle, you're the man, because those are metal. I'm torn between Tamiya metal shafts and Junfac |
10-20-2009, 03:59 PM | #17 | ||
like i said this is just my 2-cents and to give the OP something else to think about. to each his own and do what u want on your rig. drive shafts i think Eepee said it much better than i... Quote:
10-21-2009, 08:01 AM | #18 |
indeed |
10-25-2009, 07:53 PM | #19 |
I started with the Traxxis units, great but not as photogenic (i thought) s the the 3racing units. 3racing were next But spat a yoke pin on the front just wheelin', second charge of teh pack. So it was traxxis and 3 for a bit. Then traxxis started spinning the pins out of the plastic yoke on the tranny side so I upgraded both ends to GPM all steel shafts. These are great, to date. (They look cool in pics too ) I will probably end up breaking something internal as Eepee suggests, but so far all is good. |
11-14-2009, 11:02 AM | #20 |
Newbie Join Date: Oct 2008 Location: Germany
The original drive shafts take quite a beating. With a 35t-motor and a set of wheels weighting 2lbs I have yet to break one while bashing or crawling. |
