11-18-2009, 08:07 PM | #1 |
Newbie Join Date: Apr 2009 Location: Bogota, Colombia
| Integy Alloy Shock Set Blue Tamiya CR01 ????
I would like to know what do you think about Integy Alloy Shock Set? I want to change the original set and need some advice about. Thks! |
11-19-2009, 02:15 AM | #2 |
Rock Crawler Join Date: Oct 2009 Location: Wasilla, Alaska
I would recommend staying away from integy, try to give them a call tomorrow |
11-19-2009, 10:05 AM | #3 |
RCC Addict Join Date: Sep 2008 Location: Philadelphia, PA
Tamiya makes aluminum damper kit here They are Tamiya so they are probably smooth as hell and pretty. You can get it cheaper through a vendor. I use GMade Team Zero 104mm aluminum dampers from the junfac website here I got them in black but I dont see that size in black listed anymore?? They come with all kinds of stuff so you can make them up as coilovers or use them in the cantilever setup. The springs aren't great, hard as a rock so I don't use them. |
12-04-2009, 08:15 AM | #4 |
Newbie Join Date: May 2008 Location: denver
I have the Tamiya shocks (crawler specific kind) and they are very nice looking and smooth. plus 10% longer stroke than the stock setup.
12-09-2009, 04:27 AM | #5 |
Quarry Creeper Join Date: Feb 2009 Location: Seattle, WA
oh....so sad The GMade Team Zero 104mm aluminum dampers from the junfac is sold out.....didn't see anymore for 104mm size from their website.:-( By the way, Is the spring too tough or ?? Actually, I want to upgrade my shock, but don't know which shock is better for CR01 tho. But,I will try to email JunFac first anyway. ----------------------------------------------------------------------------------------- Does anyone has any ideas for upgrade the shock for CR01?? |
12-10-2009, 12:55 PM | #6 |
The GMade spring that came with my set are very hard. I don't use them.
12-11-2009, 05:33 PM | #7 |
Rock Crawler Join Date: Jul 2008 Location: Port Angeles
I have to agree with everyone who said to stay away from integy. I've thrown away more of their garbage than I've ever kept, and their shocks are the worst of their products. If you're still running your cantilevers then I'd say go with the tamiya shocks, you know they'll fit, and you know they'll work correctly. If you're doing away with the cantilevers then I'd take some measurements and head down to your lhs see if they have a shock that's close to the length you want. My Cr01 still has the stockers on it, leaky as hell but they still work lol |
01-07-2010, 05:19 PM | #8 |
Pebble Pounder Join Date: Dec 2009 Location: Ottawa
What shock oil are you guys running ? New to crawling and not sure what to put it .
01-07-2010, 08:23 PM | #9 |
Newbie Join Date: Jan 2010 Location: Picnic Point, Sydney
I was told to use 25 weight oil in the front shocks and the rear right, but to use 40 weight in the rear left to help with torque twist.
01-08-2010, 08:50 AM | #10 |
I have 45wt in mine
