Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Tamiya Scale Rock Crawlers > Tamiya CR-01
Thread: steering help
Old 12-06-2009, 08:26 PM   #1
Default steering help
there has to be something else that can help this chassis steering. i already have the 4ws but its still not good enough? i watched a video of an acx-10?? and the wheels just turned so much more. is there anyway to use the knuckles from that chassis on the cr-01???
feott is offline   Reply With Quote
Old 12-07-2009, 08:51 AM   #2
would these fit in the cr-01?
http://cgi.ebay.ca/Axial-SCX10-MAX-T...item53de6982e9
and more importantly would they help?
Old 12-07-2009, 01:41 PM   #3
Have you adjusted the endpoint on your controller so the servo gives as much throw as possible? With 4WS you should be able to turn on a dime even with the diffs locked.
860Crawler is offline   Reply With Quote
Old 12-07-2009, 01:48 PM   #4
Those won't fit the cr01 axles, bearing and shaft sizes are all different.
Steering is the biggest single downfall of the cr01 axles. There are areas on the knuckles you can shave down to get more throw, and you can grind down the cups on the stubs, but it still won't compare to what an axial axle can get.
Nate08 is offline   Reply With Quote
Old 12-07-2009, 02:20 PM   #5
im going to try the end point throw on my radio now. thanks for the replys. im still happy i went with the cr-01. maybe just because its from tamiya?
Old 12-07-2009, 02:25 PM   #6
wow that adjustment on the radio made a HUGE difference. thanks
