01-18-2010, 04:59 PM | #1 |
Newbie Join Date: Sep 2008 Location: Australia
| JunFac Joker Chassis
WooHoo!!!!!My JunFac Chassis finally arrive and with some parts also, can't wait to reach home start built in the office...hee hee Things i got from JunFac Joker Rock Crawling Chassis Straight axle adaptors for CR01 JunFac carbon steel drive shaft for CR01 Gmade shock Rest is from my old CR01 parts... Half finish in the office...... Here is finish chassis Shell that i plan to used....Custom Toyota Still haven test drive it, as still looking for decent battery and place to mount the baterry....dont like the one it show you in the web.:-( Thanks for viewing:-P |
01-19-2010, 06:08 PM | #2 |
Quarry Creeper Join Date: Sep 2008 Location: South Glens Falls
What is your initial thought on build quality? Look forward to more updates & testing! :-P
01-19-2010, 08:11 PM | #3 | |
Will test drive this afternoon after work.took me a while to workout the best way to mount the electronics... Will update more pics on the ready for action version...;) | |
01-19-2010, 09:03 PM | #4 |
Newbie Join Date: Jan 2010 Location: McDonough, Ga
Wasn't sure about the chasis when I first saw it but looks good. Might have to spend some money on another future build and go after one. JunFac is gonna make me go broke before too long.....
01-19-2010, 10:49 PM | #5 |
| Hi, The chassis is not really expensive compare to RC4WD is much cheaper and you can get similar product...rc4wd i have deal with them before...the parts are on the high side and the postage are expensive too compare with junfac...but the works are good.just we got another option to get when we want something and pay less.
01-20-2010, 03:38 AM | #6 |
here are the pics with all the gear Just finish test run the machine....very satisfy with the performance.way better than the stock CR01. got lots of travel...will do more testing this weekend if no raining......it rocks!!!!!!!!!!!!!!!!11;):-P |
02-05-2010, 03:35 PM | #7 |
Newbie Join Date: Feb 2010 Location: UK
My son and I have started the build of the Junfac Joker, we are using the Novak Rooster esc and 55 turn motor, we have 4ws, and using twin saddle batteries, one on each axle. Just doing the wiring. She has a pro-line beetle body. It's a voyage into the unknown, and will be interesting to see how it goes. Simon. Last edited by Syncrosimon; 02-05-2010 at 03:48 PM. |
02-05-2010, 07:59 PM | #8 |
Looks good, ah the wiring is so much fun,eh?
02-06-2010, 12:15 PM | #9 |
A bit more work done today, just waiting for the correct balance board to connect the batteries to the charger. |
02-08-2010, 10:06 AM | #10 |
Just waiting for the correct balance board so that we can charge those lipo batteries. Have no experience of that sort of battery, but it seems a good idea to mount on the axles. In hind site it seems a shame to break up a perfectly good CR-01, and I think what we will do is to buy the parts necessary to build up some more axles and put the CR-01 back together. The Junfac is not as light as I thought it was going to be, not sure if that matters too much, but the build quality is awesome, and is sooooo nice to look at. We are exited about painting the Pro line beetle shell and finally getting it on the trail. Simon |
02-08-2010, 07:48 PM | #11 |
Pebble Pounder Join Date: Sep 2008 Location: chicago (now in MD)
Nice rig! What do you think of the Gmade shocks?
02-09-2010, 12:34 AM | #12 |
| They actually seem to be made very well, and come with a few spares. The double internal springs seem to be balanced very well and the Joker is way more supple than the CR-01 set-up. The material quality is excellent. I have now reprogrammed the ESC for li-po, and used the Joker in the back yard, on the rock garden wall. There is a significant improvement in stability and traction from better articulation. It looks like the chassis is using the axle movement much more than the CR-01 setup. I do miss that CR-01 though and cant wait to rebuild it. Thanks for the comments. Simon. |
02-09-2010, 03:58 PM | #13 |
RCC Addict Join Date: Sep 2008 Location: Philadelphia, PA
The kit comes with G-Transition shocks? I noticed you and the OP both have them. I'd like to see how this would fare in a 2.2 comp. Probably would need to add a decent dig. |
02-09-2010, 04:45 PM | #14 |
Newbie Join Date: Jun 2008 Location: CHILE
Congratulations!!!!! JOTE |
02-10-2010, 07:27 AM | #15 |
Pebble Pounder Join Date: Jan 2006 Location: outside reading, pa
02-10-2010, 03:17 PM | #16 |
This is the first build I have done that has not come out of a box with instructions. We decided on the Junfac Joker when I we (my ten year old) and I saw the OP's pictures. The chassis is a thing of beauty and has a CNC machined look and feel to it. I have no idea what a rig should weigh, but the junfac seems heavy at 6lbs 3oz without body shell. Very pleased with the lipo's the 4200 took a 3800 mah first charge and seems to last for ever. I went with the G-transition shocks simply because they look nice and would appear to have been made for the job. The chassis now looks like it is stuck by the tires to the rock, looks completly different on the move. Big up to Spec-R for posting those first pics. Simon. |
02-12-2010, 05:37 AM | #17 |
really like your ride.....hee hee.seem better than my setup..give me some ideal to redo mine.
02-14-2010, 10:50 AM | #18 |
She is in paint now. Just playing in the garden, bodyshell needs a trim. Piloted by my 11 year old son Jack. http://www.youtube.com/watch?v=r2JIsmH99Hg Simon. Last edited by Syncrosimon; 02-14-2010 at 02:12 PM. |
02-28-2010, 08:57 AM | #19 |
Just done some more wiring mod's. I have soldered on some 90 deg 4mm jack plugs for the batteries. This gives much better clearance to the body as the wires previously just caught underneath. Also soldered on a traxxas battery connector, which gives much better contact than the Tamiya style plug. |
11-02-2010, 11:21 AM | #20 |
Just an update on the junfac. This set up has proved to be super reliable, the most reliable rc we have ever run. I now dont even take out with me any spares and a tools, and as the run time on the 4200mah lipos is between 1 and 2 hours we can crawl for most of a day without re-charging. This is a little video of my 11 yr old piloting the Joker. (please excuse the little foot nudge half way through) http://www.youtube.com/user/syncrosi.../0/9A4JMZD0Gp8 Simon. |
