02-14-2010, 05:12 PM | #1 |
Quarry Creeper Join Date: Jan 2010 Location: vancouver, canada
| replacing stock servo saver with....
i don't like the servo saver, curious if anyone has sugestions of a replacment of some modification to eliminate it. thanks in advance! |
02-14-2010, 05:15 PM | #2 |
0 0 Join Date: Jul 2006 Location: FT. Thomas
you can put a zip tie around it and that should take pretty much all the play out or just replace it with a regular solid horn
02-14-2010, 05:47 PM | #3 | |
thanks rom. | |
02-14-2010, 06:02 PM | #4 |
heres that best pictures i have of what i'm talking about. i'm sure your isn't the exact same but if i know tamiya it probably operates the same. just put the zip tie around the expanding collar. a wider zip tie than i used would be better |
02-14-2010, 06:14 PM | #5 |
great! thanks rom, i will try that tonight when i get home. btw, nice waterproof box. very much appreciated. |
02-14-2010, 08:05 PM | #6 |
RCC Addict Join Date: Sep 2008 Location: Philadelphia, PA
Just get a straight horn to fit whatever servo you're running. These things don't go fast enough to need a saver. If anything it hampers your turning if you're in a tough spot on the rocks
02-14-2010, 08:37 PM | #7 |
| yes! this is exactly why i would like to get rid of it. i am having trouble finding one for a traxxas servo, how long does it need to be? 1/2 inch...
02-15-2010, 04:31 PM | #8 |
I think I have a 3/4" horn, but I did nip a bit off at the end because I got the Junfac steering linkages and they are pretty thick so they interfered with the horn movement.
02-15-2010, 04:35 PM | #9 |
Rock Crawler Join Date: Jan 2008 Location: Eveleth
Just replace it with an aluminum servo horn. They are splined differently depending on the servo you use, so make sure to get the right one.
02-15-2010, 04:38 PM | #10 |
Rock Stacker Join Date: Jan 2010 Location: Hollywood, CA
Another vote for a solid servo arm. A servo saver will really hinder you on the rocks and any decent metal gear servo won't need it.
02-15-2010, 05:41 PM | #11 |
so what length is needed gents?
02-15-2010, 05:44 PM | #12 |
Around .75" should work. Here's the one I use: http://www.racers-edge.com/Pro_Servo...rce10384bk.htm I'm pretty sure they make a Traxxas version. |
02-15-2010, 07:54 PM | #13 |
zip-tie trick doesn't really work....solid arm here i come.
02-15-2010, 07:59 PM | #14 |
02-15-2010, 08:07 PM | #15 |
| yea, i think the standard ones use plastic, whereas the CR-01 uses metal rings, thanks for the suggestion though, definatley worth a try! thanks for the suggestion and replies. much appreciated!
