08-20-2010, 12:46 PM | #1 |
Newbie Join Date: Aug 2010 Location: Concord, CA
| QUESTION: Do RC4WD OEM Steel 1.9 Stock Beadlock Wheels Fit CR01s?
I'm in love with the OEM steelies, but need to know if they'll fit my CR01 bronco. Thanks!!!
08-20-2010, 02:16 PM | #2 |
Pebble Pounder Join Date: Jul 2009 Location: Calgary, Ab
A set just went on my CR01, they're great.
08-20-2010, 02:21 PM | #3 |
Newbie Join Date: Jul 2010 Location: PH
as long as it will fit a 12mm hex you'll be fine...i recommend getting 6mm+ offset, it'll help with stability in terms of crawling in my opinion, steering angle/radius is another problem as the offset gets larger.
08-20-2010, 02:39 PM | #4 |
Thanks guys! I'll add them to my rpp order.
08-20-2010, 05:10 PM | #5 |
To let you know 1.9 OEM Steelies are pretty thin and they pretty much only accept RC4wd tires. I run the steelies with 1.9 Dirt Grabbers on my scale truck. Do note that they cannot accept Proline tires. |
08-20-2010, 05:39 PM | #6 |
| I did read that. I'm having second thoughts now after seeing S.D.I.'s wheels and tires.
08-20-2010, 08:42 PM | #7 |
RC4wd's scale stuff is nice. I'm sure you won't regret it. What SDI wheels/tires are you looking at? I thought they only made their Trail Doc's...
08-20-2010, 09:59 PM | #8 |
08-20-2010, 10:24 PM | #9 |
Oh HPI makes them they are the stock car rims. You can find them on Tower...but on a CR-01 Bronco I think the steelies definitely will look better. Any reason why you're changing to a 1.9?
08-20-2010, 10:57 PM | #10 |
08-21-2010, 04:38 AM | #11 |
08-21-2010, 02:40 PM | #12 |
I wanna be Dave Join Date: Sep 2007 Location: San Tan Valley
The steelies are awesome wheels and at a great price! I have run several sets of the 1.9's and 2.2's with rc4wd tires and they are great. I tried Flat Irons and it was a no go, but they did work with several other 2.2 tires I had just not pro-line.
08-21-2010, 09:33 PM | #13 |
Quarry Creeper Join Date: Jan 2006 Location: North Charleston
get some 2 inch pvc, and cut it to the width of the stock rings. they will fit the flat irons and more tires. the ring is to small to fit most tires besides some rc4wd. even then, i have a set of creepers that wont fit.
08-22-2010, 11:08 PM | #14 |
Decided on the steelies and Rock creepers.
08-23-2010, 11:33 PM | #15 |
09-11-2010, 05:59 PM | #16 |
Quarry Creeper Join Date: Oct 2007 Location: Ranch
i wonder if this apply ( the 2" PVC ) To the tango down beadlocks wheels too ? |
