Go Back   RCCrawler.com Bulletin Board > Scale Rigs Brand Specific Tech > Tamiya CR-01
Thread: pinion gear
Old 12-11-2012, 10:04 PM   #1
Default pinion gear
hi guys..
wat size pinion gear should i use if i'm using e stock silvercan motor?
zero1 is offline   Reply With Quote
Old 12-12-2012, 10:52 AM   #2
Default Re: pinion gear
I believe the kit came with a 20T pinion. The smallest you can use is 16T.
Don't forget they are metric with a 48 pitch. Hope this helps.
scrofcheck is offline   Reply With Quote
Old 12-12-2012, 11:53 PM   #3
I thought they were o.6 module, not 48dp
Syncrog60 is offline   Reply With Quote
Old 12-16-2012, 11:52 AM   #4
I have had down to a 14t pinion in my CR-01 Gearbox. And as MR Syncro has stated its 0.6 module. 48dp will ruin the spur gear.
igbandy is offline   Reply With Quote
Old 12-16-2012, 12:05 PM   #5
Well there you go. I stand corrected I guess it's a 0.6 module. I was wrong/ Me bad
Old 12-16-2012, 06:35 PM   #6
Damn!! Guys u're good! Thx!
Can i actually use e stock pinion from a cc-01? It's a 16t pinion..
Old 12-17-2012, 11:22 AM   #7
Technically yes you can.
But I wouldnt, as the Tamiya stock pinions are made from a very poor quality alloy. And the teeth wear quicker than the plastic spur gear. Then the alloy pinion wears the spur gear out.
Better of trying to find a steel pinion, RW racing and Ansmann if you can find them in Singapore.
Old 12-18-2012, 12:10 AM   #8
hmm.. thx dude..
will scout for it here..
Old 12-18-2012, 07:52 PM   #9
Just curious, do you just want it to crawl slower? I was going to change the pinion gear but the guy at my local rc store recommended switching the motor over to a lathe motor. It's way more efficient and depending on the one you get a lot slower too. I also noticed a big improvement on the throttle control as well and I get about 1.5 hours of run time on a 4200 mah lipo.
Gunngee is offline   Reply With Quote
Old 12-21-2012, 07:03 AM   #10
I've ran RC4WD 80t motor wit 20t pinion. My 2yr old walks faster than it..
Using a silvercan is juz too fast for crawling n it heats up e esc n motor too.
Old 12-30-2012, 01:32 AM   #11
Tried e combo of silvercan with 16t pinion. Better torque, less heat on e motor..
But e esc heats up pretty bad. Juz burned e esc juz nw..
Only 15mins of crawling..
Old 12-30-2012, 11:50 PM   #12
You can use the Robinson metric(.6 module) pinions with no problems. I've used them with a Holmes 27T on a 3s for months and my spur gear is fine.
Robinson Racing Products - Products and Pricing - Metric and 32 pitch Pinion Gears
Dirty 'Yota is offline   Reply With Quote
Old 01-01-2013, 08:04 AM   #13
I know you can use 0.6 module pinions, its what I said.
I am using an RW racing 16t 0.6 mod pinion in my CR-01 with a rebuilt 35turn on 3s with no problems at all.
pinion gear - Similar Threads
Which spur gear and pinion gear with 35t motor vegas1973 General Crawlers 1 08-19-2012 11:42 AM
Pinion Gear tecboy Axial AX-10 Scorpion 11 01-18-2010 07:44 PM
pinion gear The_kernel114 Venom Creeper 1 07-02-2009 11:15 AM
pinion gear? ctrwannabe Axial AX-10 Scorpion 2 08-29-2007 11:48 AM
Pinion gear BIG_BLAZER86 Traxxas Maxx Crawlers 2 08-23-2005 07:01 PM
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
