11-20-2013, 12:46 PM | #21 |
Rock Stacker Join Date: Nov 2013 Location: Selma
| Re: New to crawling need advice |
11-20-2013, 01:35 PM | #22 |
RCC Addict Join Date: Feb 2012 Location: Ca.
| Re: New to crawling need advice I've recently switched to 3 cell lipos. I got them at Hobbytown USA. They are 1300 MAH 35C and sell for $19.99 each. So far no problems. I have been running three of them in three different rigs for about four months now.
11-20-2013, 02:04 PM | #23 |
Which battieries did you run when u had a 2cell set up? I'm tryin to get ideas bout battieries still! I've heard a lot of good about those gen ace battieries!
11-20-2013, 03:33 PM | #24 |
| Re: New to crawling need advice I've used Venom and Speed Pack hard case 2 cell lipos between 4000-6000 mah in the past. I've found that the 3 cell lipos give me more power=wheel speed and about an hour worth of run time. I've really become weight conscious lately and those big batteries are heavy. Not to mention that there aren't too many places to put them on a rig. The CR-01 has a large battery compartment as you already know. Not so on the SCX10's.
11-20-2013, 03:45 PM | #25 |
Okie dokie! Thanks for the help! It's wat different than rc planes it's more laid out for them but not so much for crawlers lol! Thanks again!
11-20-2013, 04:13 PM | #26 |
11-20-2013, 06:15 PM | #27 |
RCC Addict Join Date: Sep 2008 Location: Philadelphia, PA
Here you go. This is my ziptied cants Simple as that. In any case, regardless of which way you make your suspension, move your upper rear links to the upper side of the rear attachment plate like this (I put some little spacers under it) to make them a little closer to parallel to the ground. Its a little better geometry for the links. |
11-20-2013, 07:11 PM | #28 |
Ohh I see now thanks for the pics! Now I'm guessing u don't crank down on the zip tie correct? Jus a lil snug? And so the short barrel spring lower the height a lot? Nice lookin rig btw!
11-20-2013, 07:14 PM | #29 |
Thanks! Yeah you pull the ziptie as tight as you can go so there is no movement between the two parts. And yes there is a pretty good height difference from the stock springs. Less tall and tippy with the short springs Sent from my SPH-L710 using Tapatalk |
11-21-2013, 05:31 AM | #30 |
Pebble Pounder Join Date: Dec 2010 Location: UK
11-21-2013, 11:06 AM | #31 |
Ok I'll look into getting some! I'm guessing there a straight forward swap just need a Phillips head screw driver and ur good? Thanks for then help!
11-21-2013, 02:35 PM | #32 |
Those springs are just held in by 4 screws each (2 on each collar) so easy to replace. Just don't crank them in super hard or you'll strip out the plastic. The spring set from Tamiya is part #54085 if you're looking Sent from my SPH-L710 using Tapatalk |
11-22-2013, 11:47 AM | #33 |
I'm prolly gonna get a set I'm waitin for parts now to get it back goin! Thanks for the help!
12-21-2013, 07:25 PM | #34 |
We'll an update I have received my esc and motor both are HH motor is torque master pro 35 t and esc is the torque master also! Now I jus need battieries and a servo and receiver! Does anyone recommend a gearing set up I'm going to run a 2s 4000 mah battery! Idk the stock gear set up may be fine! Thanks for any input!
New to crawling need advice - Similar Threads | ||||
Newbie to crawling needs advice please. | drjav | Newbie General | 4 | 08-11-2012 07:12 AM |
New to Crawling - advice please. | drjav | Axial AX-10 Scorpion | 3 | 08-10-2012 01:28 AM |
Extremely new to crawling. Advice is welcome. | sstroudwku | Newbie General | 12 | 07-24-2011 12:20 PM |
new to rock crawling need some advice | boater | Venom Creeper | 4 | 10-23-2009 08:45 PM |
New to crawling...need some advice! | snowsurfer715 | Newbie General | 22 | 03-20-2009 01:13 AM |
