![]() | #21 |
Rock Stacker Join Date: Mar 2014 Location: Vancouver, British Columbia
I haven't figured out how I want to continue painting the grill. I'll sort it out once I finishing painting the body. Here are some shots in the paint booth. Tamiya Paints PS-1 White PS-5 Black PS-14 Copper PS-41 Bright Silver PS-48 Metallic Silver I haven't backed it with the bright silver yet. The black will be for the fenders and the white for the canopy. The Metallic silver will be used for the bumper as I had some paint left over from this build. Sorry it's not a crawler ![]() ![]() ![]() ![]() ![]() |
![]() | #22 |
Forgot to add the bumper into the mix. I'll have a lot of detail work ahead of me as I still dunno what theme to do in terms of having a roof rack, more than normal lighting, and other little bits. Ignore the paint dust on the plastic coating. ![]() |
![]() | #23 |
Rock Stacker Join Date: Apr 2009 Location: Auckland, NZ
Looking good; really want a Bronco body for mine....one day! Great colour choice |
![]() | #24 |
RCC Addict Join Date: Sep 2008 Location: Philadelphia, PA
I didn't even think of silver backing on the copper. I have another FJ body I did in Tamiya copper but I backed it with black. sent from Galaxy S3 |
![]() | #25 |
Thanks guys. I get some more parts in tomorrow to actually drive the thing around, only to take it apart for the aluminium bits whenever they show up. Good thing though is I can finally play with placement of the ESC and RX. Here are more pics. I have to add more detail to it once I am figure out some other bits. ![]() I haven't figured out how I want to fill in the grill yet. ![]() cutting the FORD out was fun ![]() ![]() ![]() ![]() |
![]() | #26 |
Finally I have my servos and drive shafts. ![]() ![]() |
![]() | #27 |
![]() | #28 |
In order to make my servo horns work (even though they were the short) required me using my dremel to cut and grind part of it off. I also had to take the front bumper off. Which means I have to figure something out for that as well. ![]() ![]() ![]() ![]() |
![]() | #29 |
Rock Stacker Join Date: May 2014 Location: Ontario
awesome paint job, and yes, awesome cutting out the letters of FORD!
![]() | #30 | |
| ![]() Quote: | |
![]() | #31 | |
| ![]() Quote:
Thanks for the likes and now I just need all my aluminum bits and some lights. | |
![]() | #32 |
I wanna be Dave ![]() Join Date: Apr 2014 Location: North Carolina
I run a hacked FlySky on my FJ40 CR01 and it is programmable for one touch switching from opposite to crab. It also is programmable to have one of the buttons vary the ratio, which is super useful. I hadn't thought to try my 4PLS on it, so I think I may try that when I build #2 in a few weeks.
![]() | #33 |
Looking really good. I think the Broncos look good without roff racks and extras but will be good to see what you decide. I had a similar issue with the servo arm so ended up not using the aluminium one but going for a short reinforced plastic one instead
![]() | #34 |
I love that copper color, have used it on several vehicles. I don't run the axle bumpers on any of my trucks. ![]() |
![]() | #35 |
I finally gave it a good run this evening for about 1.5hrs and still had 30mins left I figure on the battery. I learned that I do not have as good of articulation as my buddies Unimog due to a wider offset, lighter oil (I built his shocks), and weighted wheels. I've gotten a great baseline to work with now and was for the most part able to keep up with him. It was just that mine looked like a plank sometimes and his a creature overtaking rocks. ![]() Here are some shots over the last 24hrs. ![]() ![]() ![]() ![]() I still am waiting for my light kit as I took parts I had laying around. ![]() I am also gearing up for winter ahead of time ![]() ![]() ![]() |
![]() | #36 |
Some additions to the Bronco ![]() ![]() ![]() and my favourite bits ![]() |
![]() | #37 |
Pebble Pounder Join Date: Nov 2013 Location: Bedford, Nova Scotia, Canada
For max articulation, stabilizer bars front and rear have to go. Just no escaping it.
![]() | #38 | |
| ![]() Quote:
What I am going to do is weight the wheels and use even lighter oil (30wt currently) with softer springs. Then I will remove the rear. I've already removed the front when I went out for its maiden run. Thanks for tip ![]() | |
![]() | #39 |
I love the way your rig is looking. For what it's worth, I think you should be able to get a lot more articulation than you currently have without having to make major changes. I'm running yellow springs and the stock oil with stabilizers and heavily weighted wheels, and I get a ton of articulation. Good luck!
![]() | #40 |
thank you new2rocks. I don't figure major changes are needed either ![]() ![]() ![]() ![]() ![]() Last edited by Measuredpath; 09-27-2014 at 09:54 PM. |
Tamiya Bronco bodys! Order now! | RPP Hobby | RPP Hobby | 0 | 08-07-2009 08:07 PM |
