07-23-2016, 09:28 AM | #1 |
Newbie Join Date: Dec 2010 Location: Canada Vancouver bc
| Need help on drive shaft
this is the second time my Mip drive shaft broken (rear drive shaft ) , can anyone tell me why ? im using 27t motor . what brand drive shaft i should choose . thz for helping Last edited by marvin0010; 07-23-2016 at 09:34 AM. |
07-23-2016, 11:04 AM | #2 |
| Re: Need help on drive shaft
Wow. Can't say why you are breaking shafts, but I use Axial Wild Boars on all three of mine and they do just fine. Heck of a lot cheaper to replace if they break too. There's no slipper on a CR - might have something to do with it. |
07-23-2016, 11:15 AM | #3 |
| Re: Need help on drive shaft |
07-27-2016, 05:07 AM | #4 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
That and the driveline angels are weird on the CR-01. I am running Junfac driveshafts and was having binding issues, once I put on the short barrel springs and lowered the ride height, my binding went away. You could also add spacers to the links, etc to help change the driveline angles. I'm willing to bet that to break a MIP shaft the joint bound up during suspension cycling. Mine would bind like crazy if I ran the throttle and picked the rig up off the ground causing the suspension to droop.
Need help on drive shaft - Similar Threads | ||||
best way to join a rwvo drive shaft to the output shaft on the axle | TRAV | Kyosho Crawlers | 12 | 01-29-2012 07:37 PM |
***MIP C-Drive Drive shaft for the AX10...GIVEAWAY*** | Rockpiledriver | RCP Crawlers | 153 | 07-01-2008 11:18 AM |
drive shaft help | mindwreck | Tamiya TLT Crawlers | 10 | 08-12-2006 02:45 PM |
drive shaft ???'s | IronOx | Tamiya TLT Crawlers | 5 | 12-30-2005 12:58 AM |
