01-05-2018, 06:15 AM | #1 |
Pebble Pounder Join Date: Nov 2013 Location: Bedford, Nova Scotia, Canada
| Heavy Duty Ring and Pinion Diff Gear Options?
Hey guys. I've put a lot of miles on Mogfather, and now it is time for an overhaul. I've taken apart the tranny and it looks great. However, when I took the axles apart, the diff pinion gear was quite worn and one tooth was chipped. I am not really upset because the truck has a LOOOT of miles on it. But since I'm doing a full re-build, I figure I'll put in some better parts. I am going to be putting in the Heavy Duty (HD) driveshaft/locker combo (P/N 5410. QUESTION: I want to know if there is a HD/hardened steel diff ring and pinion gear set for the CR-01. i.e. is there a HD version of P/N 51326. Doesn't have to be a Tamiya part, but it does have to be good quality. I did try to search the forum for this but didn't find anything - sorry if someone already posted on this. Any help would be appreciated. Thanks! |
02-05-2018, 06:49 PM | #2 |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
| Re: Heavy Duty Ring and Pinion Diff Gear Options?
Supposedly the RC4WD T-Rex 60 gears fit the TLT-1axles with minimal work (I've never tied it myself so I can't say for sure). Never had a CR01 so not sure what the difference is from the TLT
02-05-2018, 07:38 PM | #3 |
I don't know of any, and I have been looking for years. The stock gears do hold up pretty well and aren't terribly expensive. I'd just swap in another set and call it good.
Heavy Duty Ring and Pinion Diff Gear Options? - Similar Threads | ||||
Heavy Duty Beveled Ring-Pinion | easleycrawler | Axial AX-10 Scorpion | 4 | 04-04-2010 09:19 AM |
Diff ring/pinion gear ratio? | tetracanth | Tamiya TLT Crawlers | 2 | 01-06-2010 12:16 PM |
Heavy Duty Ring and Pinion gears... | EagleOne | Axial AX-10 Scorpion | 5 | 10-29-2007 03:21 PM |
