01-26-2008, 07:28 PM | #41 |
01-29-2008, 01:14 PM | #42 |
Rock Stacker Join Date: Jun 2007 Location: covington
So just a little update. I went out and played last weekend with a buddy and the truck did alot better then at my first comp. I know getting inner c's, knuckles and shafts in there will help get me further but getting the EPA dialed in really helped as well. Once I decide on my components I want to loose the huge spacers to get the scrub radius down as I think that should help too. Thanks again for the help so far. |
01-29-2008, 02:47 PM | #43 |
Quarry Creeper Join Date: Oct 2007 Location: Ft. Wright, KY
Dang! Eggressor, you've made that rig "your own" very nice work! (for you other guys click on one of his pictures and learn... )
02-09-2008, 11:17 AM | #44 | |
RCC Addict Join Date: Jan 2005 Location: Germany north
http://www.youtube.com/watch?v=XZ7WEIyZkBI | |
02-11-2008, 12:33 AM | #45 | |
RCC Addict Join Date: Nov 2005 Location: Saving for Nationals!!
02-11-2008, 01:20 AM | #46 |
Pebble Pounder Join Date: Oct 2007 Location: South Africa
do i need 4 wheel steering on my tlt? or must i just change the servo horn?
02-11-2008, 02:11 AM | #47 |
02-11-2008, 02:28 AM | #48 |
i aint in america
02-11-2008, 02:36 AM | #49 |
02-11-2008, 03:43 AM | #50 |
sorry man didnt mean anything bad by it. i apologise if it seemed like that. its just im not going to take part in comps and im on a budget so a 3ch radio is out of the question right now. |
02-11-2008, 12:08 PM | #51 |
| No worries. Most people running TLT gear don't use rear steer anyways. Many are building scale replica trucks, and you don't see many trucks on the road with rear steer, or they are building a comp style rig and if the are going to use a 3rd channel, they will use it for a "Dig" setup since rear steer isn't allowed in most events, US or Non-US. Hope this helps!
02-11-2008, 10:06 PM | #52 |
thanx man. what can i do to increase steering. ive added tamiya 50808 wheel axles and shortened the cups and redid the bevel. will that be enought or do i have to buy other wheel hubs (knuckles)? *please keep in mind im trying to build my TLT on a budget and build as a tutorial for other newbies. |
02-13-2008, 08:10 PM | #53 |
I wanna be Dave Join Date: Feb 2005 Location: Burnsville
Depending on where your lower links are located, you can move the axle mount for them further toward the center of the axle. This gets them out of the way of the tires and allows them more room to turn. I made a piece out of delrin to offset the lower links toward the center a little bit. You could also just drill 2 holes through the axle case in order to mount the bracket. I am using stock inner axles and ground down stock stub shafts on my tlt. This is the amount of steering I get. |
02-13-2008, 10:09 PM | #54 |
now thats decent turning angle. ok cheap fix time: last night installed the tamiya 50808 wheel axles into my TLT which i cut and rebeveled using a dremel and DAMN my turning angle increased so much that the wheel hub (the little part sticking out onto which you install the steering linkage) actually hits the axle casing. WOOHOO check out my TLT newby build for newbies for details. |
03-04-2008, 09:46 AM | #55 |
Quarry Creeper Join Date: Dec 2006 Location: Finland
03-04-2008, 10:42 AM | #56 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
If you buy Fat Rock axles C's, I highly recommend you do the bearing mod. I shaved my Fat Rock C's and aluminum knuckles for maximum steering with my CVD's. I would highly recommend staying away from the Yeah Racing aluminum knuckles (which are the brand pictured). The machine work is very poor. The screws are often not drilled and tapped square. I even had one with the bearing mounts not drilled square. I have owned RCP, Yeah Racing and RC4WD brand TLT aluminum knuckles. From my experience the RCP brand has been the best. |
03-04-2008, 10:45 AM | #57 |
BTW, those pictures are old. I found that if I shaved the aluminum steering link, since it was solid aluminum, removed a little more from the C, and slightly clearanced the ring gear area on the axle case, I got even more turning radius. It just takes a little time, patience and good tools.
03-04-2008, 06:33 PM | #58 |
No matter what, you'll max out at 45^ since that is the max the CVD's will operate smoothly at. Mine, and Tannis' are maxed, as well as many others. But you're right, to get there, you need time and tools.
03-05-2008, 11:53 AM | #59 |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
| I'm running RCP's super-max clearance knuckles and stainless fatrock C's, and my setup maxes out the CVD's with no grinding at all |
04-18-2008, 07:00 AM | #60 |
Rock Crawler Join Date: Jan 2006 Location: Colorado Springs
Man I must be doing something wrong. I've ground down the drive cups, hit them with a cone shaped grinding stone and still get driveline input(bumpbumpbump). At full lock, the knuckle arm is hitting the fatrock C, so I know I'm going in the right direction. If you turn it the other way it will pretty much turn until the knuckle hits the axle. I have no doubt that if I shaved the C, similar to the MSD's, that the knuckle would use that clearance, the problem is that i'm getting the driveline input about a 1/4" from the knuckle arm hitting the C. It seems like if I bevel it any more the drive cup will be too thin at the top. Any suggestions? Thanks, Tom |
