Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: Another TLT parts?
Old 05-30-2005, 09:29 PM   #1
Default Another TLT parts?
Where can I get the link mount that attached the inner links to the chassis??
.... this all being based on a stock set-up....
SantozRey is offline   Reply With Quote
Old 05-30-2005, 10:08 PM   #2
http://www2.towerhobbies.com/cgi-bin...?&I=LXGKF4&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LXGKF6&P=7
i think these bags have the parts you are looking for. i thought i saw them individually somewhere though. ill keep looking.
edit: nope couldnt find them seperate from the screw bags. and that one of em is mighty expensive. if those are the parts you are looking for i think that i could part with mine. how much will you give me for them?
fuzzhead is offline   Reply With Quote
Old 05-30-2005, 10:44 PM   #3
man some of you guys are awesome at searching thru towers site.
rckjeep is offline   Reply With Quote
Old 05-30-2005, 10:55 PM   #4
.... your telling me...
I can barely ever find anything there.
too bad that Tamiya couldn't of put those parts in 1 bag.....
Old 05-31-2005, 08:29 AM   #5
Santoz, another option would be using some stand offs like the battery mounts on your chassis. Between the chassis plates is two inches. Captured balls are a 1/4" each, so you would need two 3/4" stand offs and some 4-40 threaded rod (or 3mm if you stayed metric). The stand offs are available through mcmaster, though, I would check locally because generally mcmaster has a flat rate of $5 for shipping, and the parts would only be $3. Unless you find other hardware you want on there that'd make it worth spending on shipping.
Plays_with_Toys is offline   Reply With Quote
