02-14-2008, 08:47 PM | #21 |
Rock Crawler Join Date: Apr 2006 Location: Pineville Ky
Nice paint job, rig looks great. It looks like everyone in the 2.2 class is going to have to step it up a notch. |
02-14-2008, 10:27 PM | #22 |
I wanna be Dave Join Date: Sep 2005 Location: Dirty South
02-16-2008, 08:58 AM | #23 |
well after getting 2 battery packs ran thru The HQQD Rat it is workin' good . I'm liking the wheel speed the 12 tooth pinion gear gives. I was worried about the ESC/Motor over heating . I was also worried about the motor stalling but there is plenty of power . After getting thing setup like this I ended up with 3" of center clearance . the 60/40 setup rocks !!!!! Last edited by Badd; 02-22-2008 at 10:23 AM. |
02-16-2008, 06:50 PM | #24 |
I wanna be Dave Join Date: Jul 2006 Location: Elberfeld
Lookin good badoubled! I'm running a 45t motor with a 12t pinion and a 10.8 battery pack in my s-dub-trio, and I love it. Its got amazing wheel speed and still has plenty of power. Is this your first s-dub-3? If so, you'll like it. |
02-16-2008, 07:41 PM | #25 |
| yes my first 3 ,but I have had 3 SW2 . |
02-16-2008, 07:57 PM | #26 |
Pebble Pounder Join Date: Jun 2007 Location: somewhere
Nice rig. I like the way you mounted the batt pack over the servo. I've been fighting with myself trying to find a way to put my packs on the axles. I think I might try that.
02-18-2008, 09:06 AM | #27 |
| I ran my battery packs like that in comps last year . I like that they are easy to change out . It gets the weight down lower also . Last edited by Badd; 02-18-2008 at 10:45 PM. |
02-18-2008, 10:53 PM | #28 |
I done some more testing today .The SW3 is working good for me . here is some new pics of it doing its thing . |
02-19-2008, 05:51 PM | #29 |
I ran my batteries over my servo last year . I was running a 5645 servo and it done ok . This year I got a 5995 and even though it has been cool outside the servo seemed to be getting warm . I'm sure it would get to hot this summer. I made new mounts for them . I dropped them down on the axle like on my Scorpion .I made some small plates to mount the split packs to . I stayed with a 7 cell pack , so I added 21g of weight to the left side to off set the weight . This is how they where before and now got the weight of the batteries alittle lower Last edited by Badd; 02-20-2008 at 07:30 AM. |
02-19-2008, 06:11 PM | #30 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
Lookin good!! Can't wait to crawl against it Saturday.
02-19-2008, 06:28 PM | #31 |
Nice pics Badd, truck looks good. You need some stiffer inserts in the rear tires, IMO, but if they are working good for you, so be it How is the clearance between your batts and the shock mounts? I had to change to a single hole mount to clear the batts on mine, but I run 10 cells. |
02-19-2008, 06:37 PM | #32 | |
| I willbe there as long as you come by and pick me up . I shouldbe home around 4:30am . I might sleep all the way there . Quote:
02-19-2008, 06:41 PM | #33 |
02-19-2008, 07:17 PM | #34 |
Quarry Creeper Join Date: Oct 2007 Location: Ohio
The paint looks great. Good job on those battery mounts, I like them.
02-20-2008, 08:43 AM | #35 |
02-23-2008, 09:19 PM | #36 |
well the SW3 done good today in its first comp . We (SERCRC) had around 32 2.2 and I was in a 3 way tie for 4th . but with the tie breaker gates ended up with 6th place . Rock City Rumble 3: 2.2 1. GateKeeper.........-3 2. Rockcrawler........23 3. The Rooster........28 4. RXcrawler...........31 5. RCXJ..................31 6. Badd..................31 7. JoeBrusier..........34 8. Tyler..................34 9. CSR...................34 10. Larry M..............35 not Badd at all !!!! Last edited by Badd; 03-04-2008 at 08:10 AM. |
02-23-2008, 10:12 PM | #37 |
Way to go Badd, glad it's working good for you. |
02-24-2008, 02:38 AM | #38 |
Quarry Creeper Join Date: Dec 2006 Location: Finland
Ohh, thats so stunning looking rig. Body are perfect fit for that! |
02-25-2008, 04:15 PM | #39 |
| Thank you again for the help you gave me . Thanks , I was worried at first . I thought it might be to BLING BLINGin' . After I got it finish I love how it looks and drives . here is a few pics from the comp at Little Rock City . Thanks to RockCrawler and Sven for the the pics . Out of 30 gates I only missed getting 2 progress points . 1 gate on the first course I ran (gate 8 ) and 1 on the finals (gate 10 ran out of time) not to Badd !!!!! |
02-27-2008, 09:35 PM | #40 |
This is a great mod . I have always done it on my TLT axles (fat rock Cs) after they got some ware on them . I was going to do these right away , but the bearning had not come in . They came in on Sat. when I was at the comp . If you are waiting on parts just go to a comp they will come . Anyway I knew this mod would work on the MSD axles Cs also . So I ordered four 3x6x2.5 mm flanged bearings . I drilled out the axle Cs with a 15/64th bit and press the four bearings in . I needed 4 button head screws with 1/4" of threads . so I cut some longer one down to what I needed . I put it back together & there is no play in the kingpin screws now . Last edited by Badd; 03-01-2008 at 07:35 PM. |
