02-15-2008, 02:31 PM | #1 |
Quarry Creeper Join Date: Dec 2005 Location: Orrington
| pinion slop???
was screwing around with my crawler today and realized that if i push or pull the rear driveshaft the pinion gear will pull in and out. how bad is this and how can i fix it? my rear end is locked with jbweld i think(got the crawler used). i was thinking i could shim it. would this fix the problem and what parts do i need? i tried searching but i couldnt find a sure fix. thanks
02-15-2008, 05:24 PM | #2 |
Quarry Creeper Join Date: Oct 2007 Location: Pennsyltucky
You searched!?!? Axle shimming? |
02-15-2008, 05:28 PM | #3 |
yup i read that one but it says that some people put a shim in front of the pinion and some said behind and i wasnt sure that is why i asked.
02-15-2008, 05:30 PM | #4 |
Mine seem to work fine but I would say you could probably tell whether the ring needs to come over or the pinion needs to come back.
02-15-2008, 06:14 PM | #5 |
RCC Addict Join Date: May 2006 Location: Roseville
I put one of the Traxxas Fiber Washers 5x8mm part #1985 behind the pinion gear before I put it through the gearbox bearings. I ran a stock R/P with just the shim and grease for nearly a year (about 80 hours of runtime) without fail.
02-15-2008, 07:12 PM | #6 | |
Holmes Hobbies Join Date: Jan 2007 Location: No Where
X2,That will also help center the pinon gear on the diff gear | |
02-15-2008, 07:39 PM | #7 |
i just put one of the traxxas shims in there but the gears are loud because there is almost no grease in there. what types of grease is best? from searching i came to think of white lithium...is that true???
02-15-2008, 10:28 PM | #8 |
| Exactly. Probably why mine lasted so long... I use the white lithium grease on everything. I use the stuff that isn't quite so sticky (like the high temp stuff). If I can find the tube, I will write down the name. |
02-16-2008, 01:14 PM | #9 |
got is all fixed up today. thanks everyone
