02-22-2008, 08:02 PM | #1 |
RCC Addict Join Date: Apr 2005 Location: Seattle
| BMRC BJ Build
I have never had a chassis that was not made with my own two hands, so I figured it was time. I looked around, and I like the low slung aspect of the BlackJack, so that's what I bought. Following are pics of the build, as well as mods made to the chassis as I went. You get a nice thin skid, two sides plates a 4 screws. I didn't like the sharp edges of the plates, so I just smoothed them out with some light filing. Here it is, assembled as designed. I drilled and countersunk the holes for the R2 using a slick aluminum template I made up. Here is the final state of the chassis after modding it to fit the R2D the way I wanted it. The cross supports are not part of the kit, but I felt some extra support at the extremeties. They are actually spare spacers I had from one of Double J's Trailbeater chassis's, they were a perfect fit as well. The fit is extremely tight, I had to go as far as grinding down a wire tab on the motor to get the paper thin clearance I needed between the endbell and the chassis, but it's perfect now. Here is my rear linkage setup. I am running Traxxas Big Bores. At this point, there are no internal springs. While I was into it, I tore the R2D down and replaced the shoft fork bushings with these sweet new Teflon ones. VERY NICE parts. I can now engage and disengage on the fly with zero problems. Lots of belly clearance, especially for a droop rig. All together after it's maiden run. Some WARCRC love... More to follow... |
02-23-2008, 04:37 AM | #2 |
Quarry Creeper Join Date: Dec 2006 Location: Finland
Looking good, thought that R2D with motor looks tight! How wide is that skid? Your upper mounts looks nice too, I think thats enought arti.. |
02-23-2008, 08:03 AM | #3 |
I wanna be Dave Join Date: Apr 2005 Location: Vegas
02-23-2008, 08:28 AM | #4 |
RCC Addict Join Date: Oct 2006 Location: crawlifornia
| very nice looking build.
02-23-2008, 09:10 AM | #5 |
Looks good Jerbut can it hang with mine...... |
02-23-2008, 02:31 PM | #6 |
02-23-2008, 06:20 PM | #7 |
03-10-2008, 10:32 AM | #8 |
Quarry Creeper Join Date: Oct 2007 Location: Ft. Wright, KY
Rig looks nice! But I'm kinda confused as too why the 40% is to the rear and 60% to the front? It seems that all the weight is over the back... Maybe i'm missing something....?
03-10-2008, 11:32 AM | #9 | |
The weight of the chassis may be more towards the rear, but you can get the bias back by adding weight in the rims or on the front axle. I set mine up this way as I like the way the front does most of the work, and the rear just follows right along. I really like the way mine crawls set up like that. How's it working for you Jer? I wasn't able to get to the comp over there yesterday.:-( | |
03-10-2008, 12:06 PM | #10 |
Tanis is right! I did it because his was set up that way. It worked well, I am pretty happy with the chassis!
