02-26-2008, 07:17 AM | #1 |
Pebble Pounder Join Date: Apr 2007 Location: Deer Park
| Could not find a good answer for this....
I have high lift axles and need a servo mount on the axle, can the internals of the high lift be put in the tlt case? I think so but I also think there are subtle differences in the two. I searched but didnt come up with an answer Thanks in advance |
02-26-2008, 09:02 AM | #2 |
RCC Addict Join Date: Jul 2006 Location: So Cal USA
To the best of my knowledge, the Hilift spool and pinion gears are simular to the TLT, the axles shafts are a little shorter on the Hilift.
02-26-2008, 08:29 PM | #3 |
anyone with a solid answer
02-27-2008, 01:36 AM | #4 |
Quarry Creeper Join Date: Oct 2006 Location: wollongong, NSW, Australia
The ring and pinion are very similar but the axle shaft on the high lift are longer than the ones on the TLT Shane |
02-27-2008, 02:21 AM | #5 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
Longer shafts, Diff and pinion will work along with the knuckles. Buy the case and axle shaft set for the TLT and you should be set. |
02-27-2008, 06:07 AM | #6 |
thanks for solidifying that
