03-04-2008, 10:26 PM | #1 |
Rock Stacker Join Date: Mar 2006 Location: LA
| TLT Update
so, i was out crawling the other weekend and i rolled my truck down a 30 foot river embankment. on each bounce, i was like, "its ok", "its ok", "its ok", then.... "doh!" the truck stopped and the left wheel rolled away. turns out, the outter cup axle broke: so, since i was going to have to repair it, i decided that i might as well update it as well. so i took off all these parts: and added all these parts:
i also removed the rear steering: obligatory flex shots: under chassis shot: i sure hope to god that i never have to take apart those axles ever again. it was such as PITA getting the axels rebuilt; the biggest pain was fitting the axle c's. i kept having to shave the axle housing and the axle c itself just to get it over the axle housing. on the rear, i finally had to drill out the holes in the axle c to get the screws in. but, it was all worth it. the drive line does feel much more solid and now the truck is comp-ready. although, it seems like comp-ready now-a-days also means a dig setup i was hoping for more steering (i maxed out the EPA's), but i guess its ok since the axles are near bullet proof Last edited by Sync; 03-04-2008 at 11:02 PM. |
03-04-2008, 10:33 PM | #2 |
I wanna be Dave Join Date: Sep 2005 Location: Dirty South
good list of parts , now do this and make it easyer on your servo . also you want get slop in you Axle Cs . mine are MSD but I have done it to 3 sets of Fat Rocks . Badd's HQQD Rat |
03-04-2008, 11:00 PM | #3 | |
03-04-2008, 11:05 PM | #4 |
Just easyer on the servo . the Alum or even the stainless Cs will wear with the screw head rubbing agaist them . putting the bearings in will keep everything tight . Last edited by Badd; 03-04-2008 at 11:22 PM. |
03-04-2008, 11:09 PM | #5 |
I wanna be Dave Join Date: Aug 2007 Location: santa monica
SYNC-you want to sell your old internals? I stripped my pinion/diff locker. pablo- |
03-04-2008, 11:14 PM | #6 |
03-05-2008, 01:23 AM | #7 |
Rock Crawler Join Date: Feb 2007 Location: weather sucks ,mn
you need to round bottom of axles lil better so can't catch on lips of bottom
