06-20-2005, 10:24 PM | #21 |
Quarry Creeper Join Date: Jul 2004 Location: Deland
the only thing the bushings are good for are spacers.
06-20-2005, 10:41 PM | #22 | |
Rock Stacker Join Date: Jun 2005 Location: Indian's Cupboard
Im just saying, if you drive in alot of water constantly(everyday) it isnt much fun to have to tear down the axles. Atleast it isnt in my case because my income latley cant provide for an aftermarket screw set. | |
06-20-2005, 10:54 PM | #23 | ||
If I were to rebuild/start over with my TLT axles I would suggest running bearings at the pinion and in the knuckles. The pinion sees a lot of stress and turns which equals a lot of slop after a few runs. Bearings in the knuckles is a good idea too because after a dozen runs the axle stubs flop around making crawling a precise line tough...the tire will point in various directions on it's own. Take it from a water group of crawlers.... ORCRC sees a bit of water from time to time, a few bearings will help to keep the life of the axles. Just hose them down with some WD-40 before and after each outting and water will go away Quote:
06-20-2005, 11:04 PM | #24 | |
RCC Addict Join Date: Feb 2005 Location: Crawlifornia Uber Alles
grammer-grammar latley-lately | |
06-20-2005, 11:35 PM | #25 |
I'll be sure to check that out Toyo! Thanks for the tip, i know my local hardware store doesn't but a bolt store in the northeast would. All my screws ad bolts on the axles have started to strip because of the constant abuse. Thanks Toyo, Cya p.s- Greg, You obviously misunderstood. I make a bold effort to keep "it" correct and legible. While clod on the other hand is polluting the threadand did not put alot of insight in the former post. If you wish to discuss this matter any further i suggest you contact me through the private messaging system. |
06-21-2005, 08:21 AM | #26 |
i'll pass on that suggestion and finish here. i think you may have misunderstood that clodcrawlin was joking. that's all, no big deal. cyber handshake offered.
06-22-2005, 01:50 PM | #27 |
At the end of the day it all comes down to who has a bigger d!ck. Cyber handshake. |
06-22-2005, 02:23 PM | #28 | |
I wanna be Dave Join Date: Jun 2004 Location: Centennial, CO
If all else fails, mcmaster has all the screws you need. I use them all the time. I've never paid more than $5 for shipping which rocks the socks. BTW, thanks lunardaisy | |
