06-19-2005, 08:47 PM | #1 |
Newbie Join Date: Jun 2005 Location: Kite, GA
| TLT-1 axle bearings?
Hey, I was wondering what size bearings the TLT axles use? And how many of each would I need to have full bearings in two axles? The reason I ask is because I'm building a crawler using and agermarket chassis, and I don't want to buy bearings for the whole kit. Thanks! Last edited by BeeniDAmeeni; 06-19-2005 at 08:50 PM. |
06-19-2005, 09:42 PM | #2 |
Rock Crawler Join Date: Dec 2004 Location: Grand Forks, ND
you will need 16 5x11 bearings. 2 in every knuckle and 4 inside each axle |
06-19-2005, 10:02 PM | #3 |
Rock Stacker Join Date: Jun 2005 Location: Indian's Cupboard
Correct me if im wrong but isnt their two more in each axle where the pinion comes in? Good Luck, Cya |
06-19-2005, 10:03 PM | #4 |
I wanna be Dave Join Date: Apr 2005 Location: Eastern WA
yes
06-19-2005, 10:06 PM | #5 |
oops...forgot about that. thanx guys
06-19-2005, 11:15 PM | #6 |
Rock Stacker Join Date: Jan 2005 Location: West Texas
are bearings a neccessity?
06-19-2005, 11:27 PM | #7 |
no i dont run them...yet but they would greatly improve efficiency compared to the stock bushings |
06-19-2005, 11:40 PM | #8 |
If you drive in excessive amounts of water such as myself... No they have no purpose. Good Luck, Cya |
06-20-2005, 02:32 PM | #9 |
So I need 18 or 16 5x11's ... ? Thanks for the input! |
06-20-2005, 02:56 PM | #10 |
Quarry Creeper Join Date: May 2005 Location: Auburn
well 4X2+2X2+2X2 = 16 just buy 2 packs of duratrax 5X11s at tower unless you can source rubber shielded BBs. |
06-20-2005, 03:14 PM | #11 | |
OK, thanks. 16 it is. | |
06-20-2005, 03:14 PM | #12 |
Rock Crawler Join Date: Sep 2004 Location: eureka
what are you guys talking about? you need 20 of them 2 for the pinion gear on each axle 4 for the inside of each axle and 4 for the steering hubs of each axle. so 4+4+2=10 and then double it so you can do the other axle. 10 +10 =20. lol |
06-20-2005, 03:39 PM | #13 | |
06-20-2005, 03:52 PM | #14 |
Oh yeah DUH forgot the other knuckle DARRR lol With the tamiya set you get a set of BBs for the cantis too. The tamia set is metal shielded. Vs the Duratrax teflon shields. It depends on opinions which is better the teflon should protect from dirt more and roll better but are more prone to damage from say stuff getting hung up on the drive pins or what not. |
06-20-2005, 06:08 PM | #15 | |
RCC Addict Join Date: Feb 2005 Location: Crawlifornia Uber Alles
they have no purpose? please explain. | |
06-20-2005, 07:06 PM | #16 |
I think he is refering to the rust and locking or fouling of BBs from silt and poor matinence. Personaly the damage the olites do to the shafts and stuff the annoyance of cleaning BBs is worth the time spent. |
06-20-2005, 09:21 PM | #17 | |
06-20-2005, 09:51 PM | #18 |
I wanna be Dave Join Date: Jun 2004 Location: Centennial, CO
There's an easy answer to this. It takes as many ball bearings as there are bushings you assembled it with. |
06-20-2005, 09:57 PM | #19 |
he hasnt gotten it yet, and he wants all teh stuff there about hte same size- hwo do i kno- MSN lol
06-20-2005, 10:09 PM | #20 | |
