04-07-2008, 07:24 PM | #1 |
Newbie Join Date: Apr 2008 Location: Ramseur NC
| TLT body posts..
i need body posts for a tlt where can i find them? i've looked every where.
04-07-2008, 07:47 PM | #2 |
Rock Crawler Join Date: Dec 2005 Location: Borderland Tejas
Pretty much any body post is going to work. If it's too long you can cut them down. Check the venders section, I think I saw traxxas body posts on just about all their sites (JPCustoms, RCP, TCS, etc) or tower.
04-07-2008, 07:56 PM | #3 |
i found a set of gpm alum body posts for 11$ would that be a good way to go or should i covert to another kind like you said?
04-07-2008, 08:12 PM | #4 |
If you want the bling you could or go with something like these for cheaper, and they'd be easier to cut down to a shorter length if needed to. http://www.rcpcrawlers.com/product.p...6&cat=2&page=1 http://www.ckrccrawlers.com/shop/ind...roducts_id=185 or go to towerhobbies.com and search "body posts" What I like about the plastic posts if that you can get the ones that mount from the bottom but drill through the sides if you need to mount them like that, plus add more body pins holes and cut them down. You can do that to aluminum ones but plastic would be easier and have some give when you roll. |
04-07-2008, 08:30 PM | #5 |
i think i am gunna get those duratrax ones those look pretty good and there cheap. Thanks a bunch man |
