Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Tamiya TLT Crawlers
Thread: Benz Tlt 8x8 Off Road/crawler
Old 06-27-2008, 04:16 PM   #1
Default Benz Tlt 8x8 Off Road/crawler
hello everybody
this is my 1st time on this site.i figure i share a semi crawler im building
plans are
tamiya benz semi
2.2 wheels and tires
extended cab 3 inches
rear cab exhaust
dual steering
quad axle
all wheel steering
crab walk
brushless
rc4wd tranny
workign winches
mfu system
maybe a boom/crane
etc
enjoy the build !!!
ok started with the cab,have to cut the back off and extend it 3 inches.need all the room i can get.
SEMIJOE is offline   Reply With Quote
Old 06-27-2008, 05:00 PM   #2
ok i finish the body work
cut the rails
prefitted the tranny
i used the semi suspension for the front and rear
but!!! i used the f350 spring for length and tierod for the links
also used the semi shocks
was looking for a very soft suspension
the front tires and rims came in lookin very good now,
now im waiting on rc4wd tranny,shafts and more tires and rims
Old 06-27-2008, 06:47 PM   #3
looks good man, i like this build. so im starting up for my first body modification using 2 bodys and styrene as the strength on the inside of the joint but on the outside what putty do i use for this application? and what cement or glue should i look into to make the the bodies and styrene bond together?
pedemaster-rc is offline   Reply With Quote
Old 06-27-2008, 07:15 PM   #4
looks great!!!!!!!
Vanman is offline   Reply With Quote
Old 06-28-2008, 07:58 AM   #5
i use CA and tenax-7r GLUE.dry instantly.very strong.filler i use mmd green putty from towerhobbies
if need more ideas i have a lot builds for stretching cabs
Old 06-28-2008, 08:02 AM   #6
this is coming out better then i though.really looking!
cant wait for the tranny to come in
Old 06-28-2008, 06:01 PM   #7
This is gonna be a cool thread! Love those Benz's, so many options to take with one, and an 8x8 will be the bomb!
Airmicro is offline   Reply With Quote
Old 06-28-2008, 06:20 PM   #8
thanks
i got the tranny and shaft in today
Old 06-28-2008, 07:04 PM   #9
are you going to have it pivot in the center? I've seen some video's on youtube of 8x8's, but man does the steering suck, putting a pivot in the middle would really help, although.......... how would you get the rear tires to move then................ unless you had a sep motor and tranny for the front and rear......... oh, and I'm gonna plan on watching this build.
Montigo is offline   Reply With Quote
Old 06-29-2008, 07:18 AM   #10
Sweet, I love the 8x8s, in the beginning stages of one myself, I'll be watching this one.
LAV25 is offline   Reply With Quote
Old 06-29-2008, 08:34 AM   #11
i will put this in thought ,nice idea !!!!!!
Old 06-29-2008, 08:35 AM   #12
DUDE THAT IS AN AWSOM IDEA!!!!!
Old 07-02-2008, 08:43 AM   #13
ok everybody sorry for the delay.really busy here
imso use to making semis here.have to get in crawler mind
i took the semi shock off not enough travel
so i went with tlt1 shocks . also was able to start on the rear axles
Old 07-02-2008, 11:27 AM   #14
Looks awesome. Keep it up.
LST022752 is offline   Reply With Quote
Old 07-02-2008, 12:00 PM   #15
ok heres some bottom pictures
Old 07-02-2008, 01:03 PM   #16
Im Brandon
Brandon's Avatar
Looks like your driveshaft angle is pretty flat. Raise that transmission or t-case up!! My 6x6 hung on everything with the transmission hanging to low. Looks good though
Brandon is offline   Reply With Quote
Old 07-02-2008, 04:33 PM   #17
thanx!
ok i worked more on the rear today .was able to install suspension,shocks and steering
if you notice in the rear axle i have a output shaft , hint!
Old 07-02-2008, 05:02 PM   #18
That is one cool build. Its going to be rather large.:-P
Racer4Life is offline   Reply With Quote
Old 07-02-2008, 05:09 PM   #19
its 30 inches long
Old 07-03-2008, 06:51 AM   #20
heres a video on some trucks.
http://www.youtube.com/watch?v=mwYSw...eature=related
http://www.youtube.com/watch?v=dVj22...eature=related
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
