08-19-2004, 07:42 PM | #21 | |
RCC Addict Join Date: Jul 2004 Location: The other Crawler State
| Re: TLT build "LiL Bitch" (updated pics) Quote:
Then I just flipped the bead around and slid it on the rim. It will fit like a glove with a straight cut. I put my dremal in the drill press fixture and set the depth with a heavy duty black dremal wheel on. Then just set the rim down on the deck and rotate and cut away. The cuts will be perfect. I can post demo pics for those who don't comprehend what I am saying. | |
08-26-2004, 08:45 PM | #22 |
Rock Stacker Join Date: Jun 2004
what drive shafts are you using??? is that the stock diff ? nice truck post more pics thanks TRD
08-26-2004, 09:36 PM | #23 |
Ok sorry it has been awhile but, this thing is driving me nuts sometimes. I finally bit the bullit and grabed an old Rustler in the corner and the tranny went in. I acheived a wheel base of 12.75"s. The chassie extensions are going to get trimmed and the uppers need to be shortened and hooked up. Here is a pic of the install, peice of cake. You all need to quit wasting time cutting aluminum and cut plastic, much easyer. :P The width on the stock chassie only widened about .120, not bad and still enough plastic on the tranny. Here is a pic of an extened shaft, use a Sharpy cap standerd size, it takes two caps. The male end were lengthened also, I used a peice of plastic stock from one of the trees in the kit about 1" long and reamed the hole a little. I used Surehold Plastic Surgery glue. It is a everything plastic glue. It welds it together sort of. Side view, again it is a mock up stage, there will be alot of trimming in the right spots. Another side view, and yes with this type of install you can trim the middle up 1/2" give or take. Can you say belly up!! 4"s final clearence at center with tires at 5"s and wheel base at 12.75"s center to center with tires predicted over all at 17.75. Some one told me to go big or go home, I don't go home, bigger tires????? |
08-27-2004, 04:44 PM | #24 |
Rock Stacker Join Date: Aug 2004
how did you cut the tranny could get a pic of just the tranny please thanks
08-27-2004, 05:54 PM | #25 | |
08-27-2004, 10:47 PM | #26 |
Well I had some request for pics on the Pede front rim inner bead flip. First get one of these, it's a gota have for scratch built r/c's. Set up a heavy duty black dremal cutting wheel on the drill press so the cutting wheel is here. Then gently slid the wheel into the cutting wheel while wide open rpms. BE CAREFULL!!! it will filet your fingers before you feel it!!! Leave the wheel flat on the deck and rotate the wheel to make the perfect cut. You should have this when your done with the burrs cleaned off. Then flip the bead and slid over rim. Then if you notice there is a nice reveil to drip in CA like glueing beads of tires. Just let it wick around the inside of the bead after a little sanding and cleaning. Here is the rim beside a stock width rim. Here is a Pede rear wheel, I call it the super narrow, 1.125" 8O It is next to a 2.2 HPI super nitro wheel. With narrowed wheels well, here are some "baby Kongs" Before glueing, I have some glued now and they come out sweet. Compared to stock width on same narrowed wheel. I like the profile alot better too. |
08-27-2004, 11:03 PM | #27 |
Rock Crawler Join Date: Jan 2004 Location: Santa Cruz, CA
nice job those tires will look sick |
08-28-2004, 09:20 AM | #28 |
Gold Star Baby Momma! Join Date: Feb 2004 Location: Maumelle, Ar
I have got 2 sets of those mashers and I loved them until I saw this , thanks alot!!! j/k I need some of those narrowed ones on my tc3 crawler that I have butchered together looking good kevin |
08-28-2004, 09:58 PM | #29 |
Pebble Pounder Join Date: Jul 2004 Location: Quakertown PA
Thanks for the pics Dude!
08-29-2004, 02:04 PM | #30 |
Well the chassie is done and the wheel base came out to 12.375". I messed with other wheel base measurements and this will work the best for a good balance. The belly clearence came out to 3.75. Front veiw were the batterys will be. Rear view were esc and reciever will go. Here are some pics with some fattys on for rollers. Sneek pic of the new tread pattern, going to get two more tire right now to redo the other two. |
08-29-2004, 02:33 PM | #31 |
Quarry Creeper Join Date: Jul 2004 Location: Texas!
| Re: TLT build "LiL Bitch" (chassie done!!!!)
THATS SO AWESOME!!!!!!!!!!!!!! |
08-29-2004, 08:20 PM | #32 |
Looking good! I like the look of the wider tires on the chrome rims. Would look better under a Bronco body! |
08-30-2004, 06:09 AM | #33 |
Quarry Creeper Join Date: Jul 2004 Location: In the shop terrorising the cat with the heli.
That is frickin SWEET Do my eyes decieve me or are you running a gear reduction into another gear reduction?
08-30-2004, 08:52 PM | #34 | |
| Re: TLT build "LiL Bitch" (chassie done!!!!) Quote:
Thanks for the good feed back guys, this thing was a lot of trial and error in static. Lets hope it works as good as I think it will. | |
08-30-2004, 10:16 PM | #35 |
Damn these look scale when off the rim. |
08-31-2004, 12:12 AM | #36 |
check your messages
09-01-2004, 08:44 PM | #37 | |
09-01-2004, 09:03 PM | #38 |
Here is a shot of the radio gear installed sans the antenna. The rear servo needs to go in yet but I'm saving that for when I paint the body, time goes buy quiker while waiting. another pic under side. Here is the side hill with little tires,with the bigger tires it is not much less. I couldn't help it, the thing fit so nice and clean, my Deans battery jig. |
09-02-2004, 09:57 AM | #39 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
OK that's it, I'm going to make one now. after seeing all the things you have done, I want to get started.
09-02-2004, 09:58 AM | #40 |
Wookie turned me on to these but I can't seem to order them Wookie has them but can't order untill 9/6?? I am confused or he has the hook up. :? |
