Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: Whats different?
Old 08-11-2005, 07:00 PM   #1
Default Whats different?
So can anyone spot whats different on my TLT??? I only changed one thing really (besides the fact that I don't have body posts or running gear).
Plays_with_Toys is offline   Reply With Quote
Old 08-11-2005, 07:07 PM   #2
tru
got a pic of your truck before?
tru is offline   Reply With Quote
Old 08-11-2005, 07:09 PM   #3
Hell no. Y'all should know my truck like the back of your hand. Hold on, lemme look. TSC-10 owners should see it right away.
EDIT: Ya bunch of hippies!
Old 08-11-2005, 07:13 PM   #4
tru
moved your lower links to the inside. are there any advantages?
Old 08-11-2005, 07:23 PM   #5
and m2k tires.
mike is offline   Reply With Quote
Old 08-11-2005, 07:32 PM   #6
and different springs
ILoveRCRockCrawlin is offline   Reply With Quote
Old 08-11-2005, 07:40 PM   #7
and the links are high clearence links
TylerV is offline   Reply With Quote
Old 08-11-2005, 07:53 PM   #8
No one has gotten it yet. Though a few are on the right track.
Old 08-11-2005, 08:01 PM   #9
No body mounts.
egdinger is offline   Reply With Quote
Old 08-11-2005, 08:02 PM   #10
Thats tuff. Other than the stuff they listed above, all I see are new wheels.
And I'm pretty sure I'm not correct.
KidWithAcrayon is offline   Reply With Quote
Old 08-11-2005, 08:05 PM   #11
Originally Posted by egdinger
No body mounts.
How bout ya read the post next time...
I see no difference in the chasis. I think this is just to waste our time!
Old 08-11-2005, 08:06 PM   #12
It looks like there is a second hole above the shocks (unless thats where the body posts went), and it looks like the upper links where switched with the lowers, and the lower links appear to be on top of the axle. Did i get it? Do i win a cookie?
mrwonderful is offline   Reply With Quote
Old 08-11-2005, 08:07 PM   #13
I'm not gonna rest till I say every NEW thing on that truck...
Let me start here.
Chrome HPI wheels, Masher 2ks, NO motor, new shock springs(Or re-painted), Raised Chassis Clearance, (New Drivelines maybe??? Can't tell, can't see the U-Joint), you mounted your shocks for a better stretch, removed the middle chassis Brace...
OH!!!! You did some stuff to allow for more articulation, mostly...
I wonder how close I am, do I win something?
EDIT:
Originally Posted by Everyone that said this:
I see no difference
Wow
Nova is offline   Reply With Quote
Old 08-11-2005, 08:10 PM   #14
Actually Mr. Wonderful is spot on. Here's the setup. I need to brace the link mounts better, and the rear is toed way in. I plan to see if it helps with traction. If not, I'll bring it back to 0*. Way more clearance under the links, a little under the chassis. Articulation is the same, though vertical travel is reduced because of the links hitting the chassis. This will be resolved with my next chassis.
Old 08-11-2005, 08:16 PM   #15
Damn I wrote a lot too... ah well... Better luck next time
(Hey, do you sell ANY chassis anymore???)
Old 08-11-2005, 08:19 PM   #16
1. New set of link mounting holes drilled inboard of the stock TSC-10 holes
2. Links mounted higher on the axle?
NEVERMIND... Im slow....
boxedjuice87 is offline   Reply With Quote
Old 08-11-2005, 08:21 PM   #17
No unfortunately I do not sell them anymore. I've wanted to get back into production, but I do not have a cheap enough machine shop to warrant it. Besides, I believe the chassis is outdated with its vertical pede tranny layout.
Nope, TSC-10 always had the two holes.
Old 08-12-2005, 10:51 AM   #18
Oh yeah, i win. mmm hmm, its my birthday. So what did i get?
Old 08-18-2005, 04:03 PM   #19
Badda bam! Its ready for badger on friday Including strengthened link mounts at the axle
Old 08-18-2005, 06:24 PM   #20
DISTURBIN' tha PEACE's Avatar
Nice rig P_W_T.
I really like tour link mounts, hope you don't mind if I use it too.
I've been following your progress here & on 1/18.com Good work, wouldn't expect less from you.
DISTURBIN' tha PEACE is offline   Reply With Quote
