08-25-2005, 06:37 PM | #1 |
RCC Addict Join Date: Dec 2004 Location: HELL.....
| revamped the tlt
got bored with my old setup and made a custom chassis, longer links, etc. once this gets tested in its current config i will make permenant links. also need to add some front wheel weights cause this thing is light as a feather! |
08-25-2005, 07:50 PM | #2 |
Pebble Pounder Join Date: Jul 2005 Location: vandenberg afb
| chass?
lets see that custom chass let me see her with her top off |
08-25-2005, 08:26 PM | #3 |
Quarry Creeper Join Date: Jun 2005 Location: Mendocino (NOR-CAL)
well... what i can see of that looks pretty good. but i think you could use a bigger body. harris |
08-25-2005, 08:42 PM | #4 |
Quarry Creeper Join Date: May 2005 Location: Auburn
Quite a steep angle on those links. Lets get a nekkid pic please! It looks like a CF chassis ??
08-26-2005, 03:47 AM | #5 |
ya i would like to find a bigger body, but i dont want a big 1/10 body. i have been scowering the lhs to find something like 1/12 scale. the truck is sitting higher than normal there as i just set it down, so it actually sits probably 1/2" lower once the springs settle out. i will try an get some nudey pics later. |
08-26-2005, 06:13 AM | #6 |
Newbie Join Date: Aug 2005 Location: SW Burbs
Very nice! That looks awesome!....Home Stinko is better than Lowes Are those Imex tires? |
08-26-2005, 09:57 AM | #7 |
hey dude, just looking at that pic again, you need to ditch the bumpers and move the steering links above the knuckles. i see that you have 3 of the batts on the back axle. get the other three on the front upper links or the steering servo. that will help it alot with climbing. try to lock out the rear axle without the bumper if you have the bumper on it right now. check out how i did it. here is the front. and here is the rear. i sleeved my front links in some 1/4 inch aluminum tubing. if that isn't strong enough i am going with some 1/4 inch stainless steel tho. the rear is some 6/32 allthread with aluminum tubing. works really well. cheers harris |
08-26-2005, 02:31 PM | #8 |
i have all 6 cells mounted on the rear axle. it weighs in at 4lbs even RTR. i was going to add some front wheel weights to help hold down the front end. having the cells on the rear just worked out better. as for the front bumper i was thinking about some sort of nose rail or something in place of the bumper. i just dont like the idea of leaving the front unprotected. |
08-27-2005, 06:56 PM | #9 |
Rock Stacker Join Date: Aug 2004
im really liking that rear battery setup nice job
08-28-2005, 12:30 PM | #10 |
i have run my car without the bumper for quite a while and i have had no prob with it. harris |
08-28-2005, 03:31 PM | #11 |
some nudey pics smoothie tranny skid |
08-28-2005, 06:21 PM | #12 |
looks good... you should cut the rest of your tires the same tho. how do they work like that? harris |
08-28-2005, 06:40 PM | #13 |
ya i will cut the other 2, but it is very messy, so i am in no hurry to breathe rubber again
