Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: tlt with high lift internals ?
Old 02-16-2009, 10:12 PM   #1
Default tlt with high lift internals ?
Im sure this has been posted before but i can't find it anywhere. Can the tlt internals be used in the high-lift, hilux,or tundra axle cases? I have alot of spare tlt internal parts and just wanted to know. Thanks alot.
venomous98 is offline   Reply With Quote
Old 02-17-2009, 12:05 AM   #2
The differentials are nearly the same except for the locking feature in the highlifts. But the axles shaft are different, the highlifts are just a little longer so your tlt shafts won't quite reach the outer stub shafts. BTW the knuckles and outer stub shafts are the same.
hawnmt is offline   Reply With Quote
Old 02-22-2009, 10:24 PM   #3
I just put RCP's tlt copper gears and MIP's inside my hi-lift axle. I had to trim off the stock c's and use aluminum c's. Works flawlessly.
Renslipevol is offline   Reply With Quote
