09-27-2005, 12:35 PM | #1 |
Newbie Join Date: Sep 2005 Location: holts summit
| how to put a losi tranny in your tlt
this is my first thread here, ive been lurking for awhile and thought i should start to contribute. I had a couple of the older losi xx transmissions laying around and wanted to use them for my tlt. heres what i used. http://www.horizonhobby.com/Shop/ByC...rodID=LOSA3095 and http://www.horizonhobby.com/Shop/ByC...rodID=LOSA3096 and http://www.horizonhobby.com/Shop/ByC...rodID=LOSA3013 these were used on the tranny and most were found at the lhs in the 75% off box for the tlt axles i used http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXJJ77 and http://www2.towerhobbies.com/cgi-bin...?&I=LXJJ82&P=X the losi sliders fit perfect in the traxxas pieces. ill try to get pics up when i can. hope this helps someone out that is looking for an alternative to the pede tranny. Here are some pics Last edited by lostwages; 09-27-2005 at 03:52 PM. |
09-27-2005, 01:11 PM | #2 |
Newbie Join Date: Dec 2004 Location: Nor Cal
cool, cant wait for pics...
09-27-2005, 01:47 PM | #3 |
I wanna be Dave Join Date: Jun 2004 Location: Centennial, CO
Wanna hear the downside to using losi + pede sliders? You can only 11.5" of wheelbase, or there abouts. You are definately going to want to make some extended shafts for the axle bit, or convert the tranny to pede sliders (maybe they can bolt into the pins provided? I do know the losi tranny can reach a more extreme driveshaft angle before binding up though. So you could in theory grab some more ground clearance, and because the tranny is half the weight of the pede tranny, CG would still be fine. I'm putting a chassis together right now that will have holes for both the pede and losi tranny, I just need to bomb proof the losi tranny, but I want to drive it in the meanwhile. |
09-27-2005, 04:12 PM | #4 |
Newbie Join Date: Jul 2004 Location: Gainesville, GA
Plays With Toys, what are you planing to do to bomb proof the tranny? I am running a losi tranny and would like some extra stregnth.
09-27-2005, 04:45 PM | #5 |
Pebble Pounder Join Date: Feb 2005 Location: Scott Depot
I put a losi trans in mine too. The trans already had been converted and then i just lengthened some pede sliders and got the bulletproof yokes.wallah |
09-27-2005, 08:47 PM | #6 |
I don't exactly know. I know that I need to lock the ball diff, and I wanted to see if there was a way to convert the spur to a bolt in spur, instead of the slipper clutch.
09-27-2005, 09:28 PM | #7 |
I wanna be Dave Join Date: Jun 2005 Location: On the G-Train!!!!!
Well, I know it's not a Losi but I use an AE stealth trans. It still has the slipper but I just removed the spring & put a little spacer in where the spring was & locked it down. I'd bet this would also work on the Losi. There is no slippage what so ever. As for bullet proofing, see if someone makes a steel input gear, idler gear, & diff gear. IDK about the Losi, but it's available for the stealth |
09-27-2005, 10:30 PM | #8 | |
Are you sure that Losi tranny was converted? The JRX2's and JRXT's trannies came with sliders, not exactly the same size as the Traxxas 'Pede sliders but very close. The old Losi trannies are not that tough... There are about 6 gears inside that small housing. They are 48 pitch and made of a fairly soft plastic. Back in the day when I used to race my JRX2, I used to melt a few of the internal gears, first few times it was due to a loose ball diff which caused a lot of heat. Another time was just from a nice hard landing and it stripped the gears. I still have spares in my Losi pit box. Just thought I'd let you know since you seem to be some-what mis-lead about that tranny if you bought it second hand. It looks just like my JRX2 tranny.... | |
09-27-2005, 10:32 PM | #9 |
Quarry Creeper Join Date: Jul 2004 Location: In the shop terrorising the cat with the heli.
I prefer a losi over a pede due to the size diffrence. A losi with the case hardened outdrives is difficult to lock up but not impossible. I took the handy dandy dremel with a cutting wheel and scuffed the inside and outside of the drive hubs where the diff washers sit and also the diff washers themselves then used a carbide drill bit and drilled through both outdrive halves and also the diff rings themselves. I will admit with all this done on my milling machine I still went through 2 carbide bits. The outdrives were reassembled the holes lined up and a split pin was driven through the whole assembly. I ran it for 3 months like that with no problems whatsoever, dirt dog 5 from ct bought it and ran it another 3 to 4 months and now wrx who is a member here has it and still no problems. I dont remember the gear ratio but with a 55 turn lathe motor it had tons of torque. To me it did lack a bit of wheel speed but there were other concerns when I was running it. I also used revo shafts. Very overkill but also bomb proof. They have also survived the previous owners of the truck and the tranny also held up to the revos. On the G2 prototype I am trying something diffrent with the losi as far as locking the diff. Same situation case hardened outdrive hubs but this time I cut notches on both hubs and also the diff rings. The I used medium ca glue on the assembly before it was tightened back down. This was followed by thin ca and a shot of accelerator. It may seem like a halfast attempt to lock it but it is much quicker than drilling and pinning the diffs. It will be running by sunday and given the thurough torture test as the first one was. |
09-28-2005, 06:53 AM | #10 | |
my tranny looks just like the one in the right of your pics? I took it apart and i seem to remember 2 shafts, the one the spur is on a nd a idler i think. it looked beefy to me | |
09-28-2005, 02:59 PM | #11 | |
Good luck. You won't be able to find replacement parts for that tranny unless you snag up some old JRX2, JRXT, JRX-Pro, Junior-2, Junior-T kits/parts buckets off of eBay. The Junior-2 & Junior-T kits came with molded chassis while the X2, XT and Pro came with graphite chassis. The trannies are strong enough for what they were made for... remember that these trannies debuted back in '88/'89 in the JRX2.... The transmisson will not last to hard abuse. Just keep an eye on where the outdrives bolt into the lower gear(s).... those are prone to early breakage. Most of the weakness of the tranny is becasue of the plastic used for the gears. Fairly soft compared to what is made today. Just remember that those trannies were high-tech back in '88/'89..... and that makes them older than many of the kids on RCC now! | |
