11-06-2005, 07:04 PM | #21 |
Quarry Creeper Join Date: Jul 2004 Location: In the shop terrorising the cat with the heli.
The TLT shocks are holding up great. I tumbled the G2 about 12 feet down a hill at Gr and it came out fine other than a few scratches. The 2 inch widners are holding up great but kinda need to use aluminum knuckles. The outer arm of the plastic ones are flexing a bit and I know its only a matter of time before they snap. With that much extra width theres a good bit of tire scrub but overall stability is great now. Did add stick on lead weights to the inside of the front rims which also made a diffrence. CSR drove it at GR and took it up some ledges that I thought would be close to impossible to climb. Makes me want to break his fingers. Im going to try and round up a few more losi trannys for those who are interested in one. |
11-06-2005, 07:54 PM | #22 | |
RCC Addict Join Date: Jun 2004 Location: SERCRC
11-06-2005, 08:50 PM | #23 |
XXX t or b tranny will work. I think I have one left out in the shop. If I remember correctly it has slider shafts already on it. Which should Will check tomorrow and let you know Chris. Your TXT is looking good. I have a txt tuber i've been working on for a while with some similar changes Great minds think alike. Should bake a big diffrence on the vertical stuff.
11-07-2005, 09:58 AM | #24 | |
Rock Crawler Join Date: Jan 2005 Location: Nanakuli
11-08-2005, 03:05 PM | #25 | |
Seriously thinking about tearing the TXT apart and using the axles with 2.2's on the G2, then building a *cough*CLOD*cough* for a Unlimited Comp rig. | |
11-08-2005, 03:41 PM | #26 |
Might be a bit out of scale so to speak with the txt axles. But you never know till ya try. I am setting up a G2 with cough*clod axles*cough for the atlanta comp. Will try to post some pics of it an a day or two. I do have the losi trans and I have 2 more on the way if anyone is interested. |
11-08-2005, 04:09 PM | #27 | |
Rock Crawler Join Date: Aug 2004 Location: woods cross utah
11-08-2005, 04:34 PM | #28 | |
11-08-2005, 04:35 PM | #29 | |
11-08-2005, 09:36 PM | #30 |
Pebble Pounder Join Date: Sep 2004 Location: St. Paris
your tubers look great, scale looking for sure, look tough too, if i had the money i would buy one :p, keep up the good work
11-08-2005, 10:12 PM | #31 | |
Moderator Join Date: Apr 2004 Location: In my head
Don't do it! | |
11-10-2005, 07:06 AM | #32 |
I'm going to run a stick at one comp next year. Hey Kaaina, Chris and Joey what color do you want your tubers? Last edited by aubie; 11-10-2005 at 07:48 AM. |
11-10-2005, 08:07 PM | #33 | |
11-10-2005, 08:22 PM | #34 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
Can't wait untill I get mine, should work good as a lowrider clod frame-I think I covered the high clearance thing well enough with Alf |
11-10-2005, 09:24 PM | #35 | |
11-11-2005, 12:39 AM | #36 | |
11-25-2005, 08:57 AM | #37 |
I'll take mine silver or gray with red panels
11-26-2005, 01:12 AM | #38 |
hey aubie make mine red as stated before with silver panels !!!! sweet almost there..can't wait
12-03-2005, 12:47 PM | #39 |
aloha aubie any word when these might be done? just checking. thanx ka'aina |
12-03-2005, 01:22 PM | #40 |
| Aubie told me sometime in '07. Seriously..... I heard a rumor of 12/15/05, not sure if that was from Aubie though, so take it for whats it's worth. ;) Last edited by CSR; 12-03-2005 at 01:39 PM. |
