Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya TLT Crawlers
Thread: OH SH**
Old 09-14-2004, 11:29 PM   #1
Default OH SH**
OK I screwed up big and need some help.
You know the front and rear diffs, I lock them and then I went to put in the drive shafts and one of them didnt fit all the way in. Then I adventual got that drive shaft in and then I found out that the drive shaft rod is bent so when you spin the drive shafts the whole diff moves up and down. I tried to get the shaft out and it will not even budge. So does any one know if they sell any of these parts any where? I would need a whole new diff and I would need a new drive shaft.
Thanks
TheNewbie is offline   Reply With Quote
Old 09-14-2004, 11:48 PM   #2
Default Re: OH SH**
try www.towerhobbies.com they have almost any tamiya part youll ever need.
skyjacker_rc_club is offline   Reply With Quote
Old 09-15-2004, 07:17 AM   #3
Default Re: OH SH**
remember about tower. They are a very good place to buy parts. Their prices are usually the lowest and you can find almost anything there.
pedesrule is offline   Reply With Quote
Old 09-15-2004, 09:21 AM   #4
Default Re: OH SH**
Thanks, Are the clodbuster parts the same as the tlt?
Old 09-15-2004, 09:34 AM   #5
Default Re: OH SH**
no, you need TLT parts.
CrawlinForLife is offline   Reply With Quote
Old 09-15-2004, 02:54 PM   #6
Default Re: OH SH**
I did the same thing with my TLT when I first built it. Except I used a hammer, vise and torch to try to fix it, it never worked. Heres the parts you'll need.
http://www2.towerhobbies.com/cgi-bin...LXGKG2&P=M
http://www2.towerhobbies.com/cgi-bin...LXGHJ8&P=M
http://www2.towerhobbies.com/cgi-bin...LXGKG1&P=M
http://www2.towerhobbies.com/cgi-bin...LXGK41&P=M
CustomCrawler is offline   Reply With Quote
