06-21-2009, 11:29 AM | #1 |
Rock Stacker Join Date: Jan 2009 Location: british columbia
| tlt question
hi im a noob so i need a little help.i have a tlt crawler and want to get the slipper clutch out thanks Last edited by rock-racer; 06-21-2009 at 12:28 PM. |
06-22-2009, 04:11 PM | #2 |
Quarry Creeper Join Date: Jan 2006 Location: lehi, Ut.
The stock tlt trans does not have a slipper clutch. It is belt driven with an open diff in the center trans.. The only way to get more out of it is to buy a new trans. Like an axial or r2.. The stock tlt trans is junk so dont bother trying to keep it from slipping.. Even if you locked the center spur gear under any pressure the belt will just slip.... |
06-22-2009, 05:24 PM | #3 |
yeah ok ill just go with the ax10 trans thanks |
