07-10-2009, 05:37 PM | #1 |
RCC Addict Join Date: Nov 2005 Location: Kansas
| TLT axle help
I finally got to work on my rig over this past holiday weekend, and got everything figured out and dialed in. Except for my front axle. The problem is when I'm on the throttle. The front tires seem hesitant to turn. They'll turn and "stick", then contunue turning. When I take the wheels off, it seems to ease up a bit, but it's still there... The axle vibrates BAD, it's scary bad! Full throttle is just CRAZY! I'm running an RCP R&P, MIP CVD's, Stainless Fat-Rock C's, R2J Knuckles, and full bearings. Right now, I'm using a (cherry) red grease, it's cheap, and probably doesn't work the best, but I thought it'd be better than nothing... I took everything apart to see if I could find an obvious answer to my problem, and couldn't. The teeth on both the ring and the pinion look fine, the splines on the CVD's are fine, the part of the CVD that pivots is all together, tight, and working properly. I checked each bearing to make sure they still spin alright, and even replaced one. Another thing I noticed is that the hexes are tight (as they should be) on the CVD... no slipping hexes. I thought my problem might be with the RCP R&P. Maybe it's not shimmed correctly? I'm running the same R&P in the rear with stock shafts and no shimming, and it's perfectly fine... Does it sound as though I bent a CVD? I couldn't imagine that happening, as I haven't even ran a full pack through the truck since installing em I also thought that the vibration could have something to do with my knuckle/axle c combination. Maybe my setup isn't completly straight with the servo centered... like my c's got worn and now my knuckles are sloppy... but again, my c's aren't too old either. The knuckles I had for a while (about 6 mo's), but I changed the hardware on em, and still had no luck... I really want to crawl! Please help! Thanks in advance for any suggestions -Greg |
07-10-2009, 06:40 PM | #2 | |
Greg did you check the splines on the axles going into the ring for metal shavings I have had the axle remove the splines inside the ring and then they will do some strange movements until completely stripped. Stainless axles make the problem even worse they can eat those alloy rings pretty easy. | |
07-10-2009, 06:55 PM | #3 | |
Good thought though! I never woulda thought of it... | |
07-10-2009, 08:53 PM | #4 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
have you tried installing the knuckles with bearings and slipping a straight shaft through the knuckle into the axle tube to make sure the knuckles are aligned with the axle tube and internals? i have aluminum C's and when they get a little tweaked they can get out of alignment with the axle tube and thus out of alignment with the internal bearings,,,only happened once but it did,,,tweaked the C's back into alignment and all was good if you have a high speed drill chuck the pinion in it and see what it looks like as it spins,,might be able to chuck the ring or the entire diff internal and do the same thing just a thought Last edited by rmdesignworks; 07-10-2009 at 08:56 PM. |
07-10-2009, 09:25 PM | #5 |
I wanna be Dave Join Date: Dec 2005 Location: Gold Bar
Try pulling the front off, set it on a bench and rig up some sort of a driveshaft to a drill and see what happens
07-10-2009, 09:51 PM | #6 |
Rock Crawler Join Date: Oct 2006 Location: Fernley
Might want to make sure you got the left and right knuckles on the correct side. I screwed this up once. Caused major binding.
07-10-2009, 10:36 PM | #7 |
I'll check alignment of the c's with the axle tube and internals tomorrow after work (good idea btw) I unfortunately don't have a high speed drill... rhett: another good'n to check (I overlook simple things alot...) |
07-10-2009, 11:46 PM | #8 |
Rock Crawler Join Date: Aug 2004 Location: woods cross utah
what does your front pinion angle look like?
07-11-2009, 12:09 AM | #9 |
My front pinion isn't HORRIBLE (I don't go through yokes at least...), but since I can't bring myself to get clocked c's, it's not perfect...
07-11-2009, 12:21 AM | #10 |
07-12-2009, 11:44 AM | #11 |
| I just think they look bad... cause when you tilt the axle and get the knuckles how they should be, the steering servo just looks stupid, and the linkages don't look right... personal preferance I know... I figured it out! Not sure what it was, but whatever I did, it worked... I might have had the knuckles and c's on the wrong side... having them on the wrong side would have thrown off my alignment, so I imagine that's what was wrong... Either way, I'm ready to crawl again Thanks again to everyone who replied |
07-12-2009, 06:30 PM | #12 |
Whatever I did, didn't work... It's alot better though, but still there... I couldn't help myself today though... I had to crawl! |
07-12-2009, 07:56 PM | #13 |
RCC Addict Join Date: Feb 2007 Location: MS Coast
Back off on your wheels nuts about 1/4 turn. If they are overtight it will cause some binding also.
07-12-2009, 09:15 PM | #14 |
