Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: Shaggin' Wagon.......Stage 2 Build-up
Old 01-03-2006, 06:44 PM   #81
hey bender, you got any of those to go? im ordering one tommorow when i get home from work.
diablo0072k is offline   Reply With Quote
Old 01-03-2006, 06:45 PM   #82
2006 2.2 National Champ
BENDER's Avatar
They're in the works, the first couple will start shipping either tomorrow afternoon or Thursday morning.
BENDER is offline   Reply With Quote
Old 01-03-2006, 06:54 PM   #83
This is so cool! I just replied to this with my phone!
racerx is offline   Reply With Quote
Old 01-03-2006, 06:58 PM   #84
Sorry I never had a phone that had web access before! What a dork huh! It's pretty sweet seeing the RCCRAWLER page pop up on it for the first time!!
Old 01-03-2006, 09:42 PM   #85
slowrockr's Avatar
Hey I noticed in some of the pics of your buildup you drilled holes where those little plastic "bumps" were on the axle for the upper link mount. Did the mount flex that much?
I have no idea why I quoted that. I just hope I'm not too far down the list
slowrockr is offline   Reply With Quote
Old 01-03-2006, 10:11 PM   #86
BENDER's Avatar
You're not far down the list.
I drilled those 2 extra holes just to avoid shaving the nubs off. I ran the prototype chassis for months without screws going through the nub tabs, without any problems. But, after drilling holes and running a couple screws through the tabs, it makes the mount alot more rigid. My mounts are actually a little thicker then needed. I'd rather over build a little, then under build a little. You do have to trim the rib that runs along the top of the axle, so the servo/link mounts sit flat on top of the housing. I took a Dremel and sanding drum to mine.
Old 01-04-2006, 07:34 AM   #87
Thumbs down
I'm using my own link mount and they don't even come near the "nub's" seems very stiff! I also used angle alum. to mount the servo not the plastic kit parts maybe that has something to do with it? I took it out the other day and crawled some broken concrete piles by my house, it was OK but not the same as rock! I did manage some carnage though, broke 3 out of 4 "c's" off the rear axle! I didn't even know it till I started taking it apart to figure out a rear lock out spacer and found them cracked and barely hanging on!! Anyone know where to get the "D parts" couldn't find them on Tower or Ultimate Hobbies.:neutral:
Old 01-04-2006, 01:39 PM   #88
BENDER's Avatar
Here's a link to the axle housings on Tower Hobbies site, it looks like they're out of stock though.
http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXGHG0
I just ordered a couple from them last week and they were in stock. I guess I ordered just in time.
Old 01-04-2006, 06:05 PM   #89
paypal sent, whats the ETA
Old 01-04-2006, 06:31 PM   #90
Is this a common problem? Should I stock up on extra's? I was looking at it last night and was trying to come up with a way to make new "c's" out of alum. and kinda "clam-shell" the end of the axle after removing the stock plastic part.
Old 01-04-2006, 06:53 PM   #91
hey racerx johnstown, thats pretty close were gona have to wheel sometime
Old 01-04-2006, 07:13 PM   #92
Where you at? I live about 1/4 mile E. of I 25 on HWY 60.
Old 01-04-2006, 07:49 PM   #93
BENDER's Avatar
Thanks for the order.
All orders will be in the mail by next week, the first couple are going out tomorrow.
I've only broke one housing and that was just recently, I think I've seen about 4 or 5 break total. It's without a doubt the weakest point on the axles.
Old 01-04-2006, 10:34 PM   #94
slowrockr's Avatar
I think someone that knows how to run a cnc should make a brace.
Old 01-05-2006, 10:30 AM   #95
I agree! I was getting to that but slowrockr beat me to it!! A brace or metal "c's" just cut of the stock one's and bolt up some nodular iron!! Would also add some weight to the bottom of the truck, NO more BB's!!
Old 01-05-2006, 01:23 PM   #96
BENDER's Avatar
I'll have to sit down and look a housing over to see what can be done.
Old 01-05-2006, 01:41 PM   #97
now you are talkin' , axles braces and rear steer lockouts, make it happen cnc master.
Unimoger is offline   Reply With Quote
Old 01-06-2006, 08:27 AM   #98
Do it! Do it! Do it! Do it! Do it! Do it!
Old 01-13-2006, 07:24 PM   #99
status report on my chassis, im dyin here.
Old 01-13-2006, 07:45 PM   #100
BENDER's Avatar
Ygpm.
