05-29-2006, 09:42 AM | #141 |
I wanna be Dave Join Date: Sep 2005 Location: R.I.P. Chip
COOL ! Because I run an EVX and it has the same bec spec I believe. I can't wait to see the new setup in action. I need to sell something now... Damb it!
05-29-2006, 11:12 AM | #142 |
RCCRAWLER TEAM DRIVER Join Date: Jun 2005 Location: Voiding warranties
we have to stuff my lipo in it this weekend and see what shakes loose , the only problem I see is it would lighten your front up to much.
05-29-2006, 12:53 PM | #143 | |
I wanna be Dave Join Date: Jan 2006 Location: Albuquerque
05-29-2006, 06:48 PM | #144 | |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
I was afraid with all the torque the Revolver motor generates, I would be breaking more axle housings. So, I applied some thin CA around the ears that the outer knuckles screw to. This definitely beefed up the stock plastic TLT housings. It eliminated the flex around that area when in hard binds. | |
05-29-2006, 06:57 PM | #145 | |
I still think I'll try your trick w/ the CA. though. Great idea! | |
05-29-2006, 06:59 PM | #146 | |
10-27-2006, 08:34 AM | #147 |
damn! ive got the TLT bug now! (no pun intended) ;) do you have any straight on side shots with the body off? both sides if you got it. cause it looks like the motor and spur actually stick outside the frame! thats crazy. (clod man here lol) im a shaftie newb. |
10-27-2006, 08:41 AM | #148 | |
10-27-2006, 08:44 AM | #149 |
does the motor side sag?
10-27-2006, 08:46 AM | #150 | |
11-10-2006, 01:43 PM | #151 |
RCC Addict Join Date: May 2005 Location: I live Here
| question
when you mention 84t spur and 12t pinion are these separate parts i can;t seem to find these all i see is 12 - 48 but where does the 84 come in ? sorry fo rthe newbie question, but since i am decided on buying your chasis maybe you would oblige on the answers thanks |
11-10-2006, 04:06 PM | #152 |
RCC Addict Join Date: Oct 2005 Location: Trussville, AL
the 12-48 is 12tooth-48pitch pinion for the motor and the spur gear on the tranny is 84tooth-48pitch. oh and they are separate parts
11-10-2006, 11:25 PM | #153 |
That's it. ^^^
11-11-2006, 06:06 PM | #154 |
| thanks
thanks ! ! ! can't waitfor my sw2 bender is this rigthe one you won the national championship? if not could you post the link to the build up for that rig ? thanks again |
11-11-2006, 06:13 PM | #155 |
This is the rig I won the Nationals with, but I modified it a little since this thread. You can see the version I won with here. National Comp Rigs....... |
11-11-2006, 06:21 PM | #156 | |
Rock Crawler Join Date: Jan 2006 Location: In the basement
11-14-2006, 08:31 PM | #157 |
Newbie Join Date: Nov 2006 Location: chicagoish
hey bender, i am thinkin about building one of these Sw2's, and i was wondering what pinion you used from where, and if revo pushrods would work instead of max tierods, maybe because they are too long or something.
11-14-2006, 09:21 PM | #158 |
Any pinions will work, you just have to make sure the pitch (angle of the teeth) is the same on the spur and pinion gears. I use Revo links on mine and I like them, they are stronger than Maxx links and don't have the hex in the middle so they are smoother. They are a tad to long for a comp rig, I had to shorten mine at the Nats. alot of us from Co. were an 8th of an inch or so to long Here is a pic of mine. |
11-15-2006, 01:01 AM | #159 | ||
I was a little skeptical about the durability of the relieved SW2, but it has held up fine. Quote:
11-20-2006, 11:13 AM | #160 |
| link question
Bender What setup do you use on your tlt rigs ? ? ? 50/50 or 60/40 Thanks for the input |
