Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Tamiya TLT Crawlers
Thread: Chassis Choices question
Old 09-18-2009, 06:43 PM   #1
Default Chassis Choices question
I'm just getting back into crawling after a lengthy hiatus and i'm in the process of re-doing my XRC chassis'd crawler.
I don't really know what, if any, new developments have come about with chassis for the TLT axles in the past 2 or so years.
I thinking i would like a tuber as I don't like running bodies, but I don't have the skills to build one myself. I also like the ultra low chassis that a few people are putting together for the Losi's and Axials.
So I quess my question is two-fold.
#1 What comp chassis would you go with if you were starting a TLT rig right now? and
#2 If you went the tuber route, who here can make me a good one without breaking the bank?
ComingApart is offline   Reply With Quote
Old 09-18-2009, 07:01 PM   #2
if i were starting fresh on a TLT comp rig, i'd look at 3 chassis.
mayhem ls2.0:
http://mayhemengineering.com/Chassis.html
http://www.rccrawler.com/forum/showthread.php?t=173679
CDW 1.0
*****CDW 1.0 Comp Chassis*****
Vanquish Incision
Vanquish Products Incision Chassis
as for tubers, look at metal fume fabrication and death metal garage in the vendors section..
dieselfuel is offline   Reply With Quote
Old 09-25-2009, 11:49 PM   #3
Default Another option
Another option is the Axial Ax-10 chassis.
That's the way I went. Made my own links with allthread inside aluminum tube. Trial & error with your links. Simple to make with a hacksaw & vise. Your imagination is your only limit.
scrounge is offline   Reply With Quote
Old 09-29-2009, 11:44 PM   #4
i actually used a axial base chassi and all axial links and a r2dig trans and it worked excellent.ran like a axial
twisted bender is offline   Reply With Quote
Old 10-02-2009, 11:58 PM   #5
ah, don't forget the groundhaug marauder chassis...but skip the axial. it's a stock clunker for sure. great platform, but still...
minor_threat is offline   Reply With Quote
Old 10-04-2009, 01:58 PM   #6
I fully agree with dieselfuel... the Mayhem ls2.0, and the CDW 1.0 are both really awesome, the Incision is probably an awesome chassis too, but the looks alone turn me away from it...
The Hellstrom from JP is an awesome chassis too, and it's cheaper
grob23 is offline   Reply With Quote
Old 10-04-2009, 02:04 PM   #7
MODERATOR™
EeePee's Avatar
Gatekeepr's GC-1 chassis
Probably what I'd get.
EeePee is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
