09-27-2004, 11:04 PM | #1 |
Pebble Pounder Join Date: Aug 2004 Location: California
| Hexs sizes
Hey does any one know the adapters I will need to fit maxx size rims? Is it 17mm. And are the ones at inetrc.com the right ones? Thanks |
09-28-2004, 06:12 AM | #2 |
Quarry Creeper Join Date: May 2004
| Re: Hexs sizes
if you mean the alloy wheels hexes for the tlt that inet makes then no those just replace the stock wheel hexes. If you mean the wheel widners then no those use the same hex its just wider. If you mean something else i havent seen on the site please post a pic or link please.
09-28-2004, 09:31 AM | #3 |
Rock Stacker Join Date: Jun 2004 Location: Hillsboro, OR
| Re: Hexs sizes
The T-Maxx hex is 14mm compared to the 12mm that comes with the TLT. I would suggest you make your own hex adapters, it's easy and cheaper to do than buying them from a company. I do this with my TLT and I actually have tighter tolerances than the manufactured adapters. All you need is some metal cutting shears ($12.00 to $24.00 at home Depot) and some 1mm sheet aluminum (.032 works also). All you need to do is cut a strip that is about 2.5" long and about 3mm wide. Then wrap it around the stock TLT hex to size it up and get the bends correct. Once you have it shaped, use some epoxy and epoxy the hex into the wheel hex of the T-Maxx tire you are using. Works great and I've had no problems with it at all. |
