12-07-2005, 09:43 AM | #1 |
Quarry Creeper Join Date: Nov 2005 Location: Western, NC
| oil and spring weights
Yes I did search beforehand, and I looked in the newbies guide thread. I'm doing the TLT to crawler for noobs, and I need an idea of what spring and oil weights to get in the ballpark with a maxx shock. Thanks guys.
12-07-2005, 09:59 AM | #2 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
I run Losi red buggy springs in the rear of my TLT, and Losi white buggy springs in the front. The whites are longer, so threaded bodied shocks are nice. I run 20wt oil in all 4 shocks.
12-07-2005, 10:06 AM | #3 |
Quarry Creeper Join Date: Feb 2005 Location: Indy-Westside
I'm running stock maxx shock bodies and springs, and 20wt oil, but w/ 3 hole pistons... Edit: Thats one of the better noob questions I've seen in a while... |
12-07-2005, 10:26 AM | #4 |
Quarry Creeper Join Date: Oct 2005 Location: MD
Orange Losi Fluid. Not sure of the wieght or if they still sell it. The bottle I have is about 10+ years old. I have no complaints with Losi Fluids in any of my past hi-speed trucks. Here are some part numbers/weights LOSA5212 Silicone Shock Oil,17.5 Wt,2oz 3.50 LOSA5213 Silicone Shock Oil,22.5 Wt,2oz 3.50 LOSA5214 Silicone Shock Oil,27.5 Wt,2oz 3.50 LOSA5215 Silicone Shock Oil,32.5 Wt,2oz 3.50 LOSA5216 Silicone Shock Oil,37.5 Wt,2oz 3.50 LOSA5218 Silicone Shock Oil 45Wt,2oz 3.50 LOSA5221 Silicone Shock Oil,15Wt,2oz 3.50 LOSA5222 Silicone Shock Oil,20Wt 2oz 3.50 LOSA5223 Silicone Shock Oil,25Wt,2oz 3.50 LOSA5224 Silicone Shock Oil,30Wt,2oz 3.50 LOSA5225 Silicone Shock Oil,35Wt,2oz 3.50 LOSA5226 Silicone Shock Oil,40Wt,2oz 3.50 LOSA5227 Silicone Shock Oil,50Wt,2oz 3.50 LOSA5228 Silicone Shock Oil,60Wt,2oz 3.50 LOSA5229 Silicone Shock Oil,70Wt,2oz 3.50 LOSA5230 Silicone Shock Oil,80Wt,2oz 3.50 LOSA5231 Silicone Shock Oil,90Wt,2oz 3.50 LOSA5232 Silicone Shock Oil,100Wt,2oz 3.50 LOSA5240 Shock Oil 6Pk,20,25,30,35,40,45Wt. 18.95 LOSA5241 Shock Oil 6Pk,50,60,70,80,90,100 18.95 Last edited by CronusTRD; 12-07-2005 at 10:30 AM. |
12-07-2005, 12:33 PM | #5 |
Sinking with the ship Join Date: Mar 2005 Location: El Capitan...sole survivor and sinking fast
| shocks
I have tmaxx shocks on both my current working crawlers (4runner isnt done yet) and I run 20 wt, with losi whites and yellow springs (yellows are a lil bit stiffer so i put them in front where the battery is to control the sag a lil bit), I also drill aditional holes in the pistons and enlarge the 2 or 3 current ones, typically i have 4 holes in them to increase flow. Mike |
12-07-2005, 07:16 PM | #6 |
Newbie Join Date: Dec 2005 Location: washington
I am guessing that the maxx springs that are available are too stiff for the tlt, so ppl use the losi springs, a bit more stiff to make up for the length? I am hearing 20wt and losi buggy springs to be used with maxx shocks for the tlt. Sounds odd to me, thats why I am asking. What about something like this, what springs if any can I use with said shock? Or this, again same question, anyone have any idea what springs would fit? Is there any reason to use these shocks over maxx shocks, they are about the same length. |
12-07-2005, 07:39 PM | #7 | |
Rock Crawler Join Date: Aug 2005 Location: Concord, NC
| Quote:
I don't think there is a "perfect setup" with crawlers. These are not store bought and are not all the same. Weight, CG, shock angle, etc, etc all enter in to the mix. There is a certain amount of trial and error. I think you see a lot of Maxx shocks because they are cheap and easy to find. Basically the Integy piggyback that RC4wd is selling is a Maxx hopup shock. It's just more shiney. Get yourself any 4" shock and start tuning. Your truck, the terain your running on, and your driving style will determin what spring you need. | |
12-07-2005, 08:12 PM | #8 |
As long as I have easily available spring options, then I am happy. Given the choice I would go with the pig shocks, assuming the spring options. I will most likely purchase said shocks. I welcome more input on the topic, I am not set in stone. |
12-07-2005, 10:07 PM | #9 |
Wow, thanks alot guys. Well the TLT finally showed up along with the stuff from Tower yesterday . I assembled the axles, and attached them to the frame tonight just to check everything out. Lathe motors are backordered until mid Dec, d%mn!! Thanks to this site, and some of the members like Bender and Burban and others its going smoothly. The maxx shocks are definately to stiff with the stock spring, oil weight once the rig is complete I'll start tuning.
12-08-2005, 07:38 AM | #10 |
Pebble Pounder Join Date: Oct 2005 Location: I need MORE GIGGLE JUICE
The msr4's are a good shock. Have a set on a t-maxx. I like the plain old stock maxx shocks, cheap, they work, I have several sets with different wt oil/piston setup. RCRavin offers a progressive spring that starts out softer than the red maxx springs.
12-08-2005, 07:50 AM | #11 |
Anyone know the weight of the oil that comes with a TLT?
12-08-2005, 07:58 AM | #12 | |
| Quote:
