11-10-2005, 08:20 PM | #1 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
| The Blue Rubi
HERES MY ALMOST FINISHED TLT . Let me know what think 14"wb pede tranny extremely cut up stock chassis (for now) futaba radio and servos(aws) evx speedo gotta get lathe motor and 9t pin. and fab up a new chassis moabs will come later im runnin imex pullers on narrowed front pede died black maxx shocks with 45wt fluid and white losi stadium truck springs sorry this one is fuzzy Last edited by bigflex; 11-14-2005 at 08:04 PM. |
11-10-2005, 09:14 PM | #2 |
Pebble Pounder Join Date: May 2005 Location: Nor Cal
are you runnig jato shocks?
11-10-2005, 09:19 PM | #3 |
sorry i forgot to put the shocks on the list i have edited it now
11-10-2005, 09:30 PM | #4 |
ok thanks
11-11-2005, 08:46 AM | #5 |
Great start man! Have fun with it now, because once you upgrade to a better chassis or build your own you will really appreciate its performance I also like the look of it with the pullers!
11-11-2005, 10:20 AM | #6 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
14" WB damn I thought mine was long. looks good though
11-11-2005, 10:27 AM | #7 |
Quarry Creeper Join Date: Jan 2005 Location: Westchester
Why are you running an EVX. Seems like alot of unneeded weight and expense for a lathe motor. Looks nice and clean... What kind of links? |
11-11-2005, 01:26 PM | #8 |
For the same reason you use a super rooster with a lathe... More power, dont have to worry about frying it, and im not sure about the evx, but the super rooster can handle two high torque servos. Im sure the evx is similar.
11-11-2005, 10:21 PM | #9 |
| the evx
to be honest i was plannig on getting a rooster for it when i ran across 2 new evx's on ebay for 90 bucks i needed a speedo for my clod as well so getting 2 for less than a used super rooster was a no brainer for me . kind the kill 2 birds with 1 stone thing.and yes it does great with the 2 servos on the tlt cause im only runnig 1 motor . on the clod im having to run a reciever pac the stop the glitching. and the links are acually clod steering links sleaved with 3/16 aluminium tubing. they seem to be holding up pretty good but if a prob. arises ill just make some 1/4" links. and thanks for the complements |
11-14-2005, 10:12 AM | #10 |
Rock Crawler Join Date: May 2004 Location: DFW, Texas
Jeep looks nice! Looks like a pretty good build. I hope we can go crawling sometime. :-D What do you think of that Stinger motor in there? any good for crawling? |
11-14-2005, 05:05 PM | #11 |
Cman: the stinger is ok for the trails but a little weak for any heavy crawling. + its uses up more juice that i like. im gonna install a lathe pretty soon . i can gear it up if i need to for speed but it will be alot better all around. thanks for the complements. and ill be gettin in touch with you on crawlin with you pretty soon. later bro |
11-14-2005, 06:58 PM | #12 |
Newbie Join Date: Nov 2005 Location: Grand Rapids
Looks great! How are the pullers working out for you?
11-14-2005, 07:59 PM | #13 |
hey GH. thanks for the complement. and the pullers are suprisingly working pretty good. the tread is a little hard but the sidewalls flex enough to make up for it . and the wheels being narrowed pulls them in so that the lugs poke out so as they grab when articulated. im not running inserts in them either. and the spacing between the lugs is perfect. thanks again |
11-14-2005, 08:50 PM | #14 | |
11-14-2005, 09:01 PM | #15 |
Newbie Join Date: Jun 2005 Location: Phoenix
Good lookin rig. I am running the same body. I notice that you cut yours off at about the same spot in the back. For some reason that seems to be the only place that rubbed on mine. Dan |
11-26-2005, 11:59 PM | #16 |
well i got the lathe in and it made a world of difference. it actualy crawls pretty good concidering it still has the cut up stock chassis. im still gonna build a new one for it thogh so i can get its full potential. and lay that pede tranny down to get the weight lower. ill post pics as soon as i finish the new chassis.
12-17-2005, 09:47 PM | #17 |
bump
12-17-2005, 11:27 PM | #18 |
Quarry Creeper Join Date: Aug 2005 Location: Crawlorado
you gonna run a 32 pitch spur or something? smallest 48 pitch pinion I have seen is 12 (there could be smaller) 12/90 and 45t lathe on mine and it was slow.... much happier with the 12/87 gearing now
12-17-2005, 11:30 PM | #19 |
Rock Stacker Join Date: Jan 2005 Location: Windsor/Detroit/Edmonton CANADA
Clean.....looks good!
