Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya TLT Crawlers
Thread: My LEO X Crawler's WIP
Old 01-01-2006, 07:47 PM   #1
Default My WMG/LEO X 4WS Crawler's WIP
07/06/2005
Hi,
I finished my frame and I went up the unit
I have to find a means of placing the reducer flat, that reduces the gravity center by 2 cm
I use 2 lipos of 3.4 v for a large profit of weight
Here I have it make lightest that I could 655 gr.
The unit is not finished yet it remains to me the Cardan joints to be resoldered, to change the parts of connection of the higher bonds, to cover the bonds with tube aluminum, to make small a bumper aluminum on the front then that in I would have another nose gear I would put the unit in 4WS.
07/06/2005
Here it is done I have to turn with presently it is brilliant, it crosses the obstacle really well
Here Cardan joints cut and welded cold in an aluminum tube.
12/30/2005
Here it is almost finished
I passed the aluminum rockets, put the axes (steamless steel) + the hexagons aluminum.
I have remake and to move the support of the reducer, to bring it closer to the transmission, what makes it possible to be able to incline more the shocks postpones (in the past) can that the frame is entirely reversed, the back is now the front to put the weight of the engine ahead possible, can that I oté for a frame way "60/40"
With the passage in 4WS, I could not put the lipos any more on the bridges because that touched the crossing, look it was not good, and especially that went up the centre of gravity. I thus decided to place them at the XMods way, on both sides frame
I have to buy a servos reverser , the place being counted I placed it longitudinally, against the receiver. With the agmentation of the number of wire, the frame becomes a little tumble.
Now it turns in good better.
The front (in the past back)
The back (in the past front)
The distribution of the weight forwards "60/40"
I moved the electronique one for which master key right in the cabin of the body, what enables me to drop it by 1 cm
The 4 links + the back Cardan joints, one lengthened summer of 2 cm, what carries the footing to 18.3cm and the length total with 25.5cm
I recut the edges interior of the rims to keep only a colerette, then I recut a band 5mm on the interior and then restuck the rims. One cannot not cut the colerette external dů with the drawing of the rim but I use the colerette intern all the same. The pneux ones one boiled and rafters recut (only one on the photographs) for a flexibility increased.
A wheel raised to 13 cm and 3 others on the ground.
Almost 80° of crossing of bridges
The 4WS multiplies the possibility of trajectories
I must still make the two bumpers, to remake the 2 plates of the frame (with clean) and I think that that I would not touch there any more! has less than... for the wheels...
I am with the listening of your comments and councils. By advance Thank you
Nico14
ps: I'm sorry for my bad speaking but I'm french
nico14 is offline   Reply With Quote
Old 01-01-2006, 08:16 PM   #2
thefordmccord's Avatar
It looks pretty damned cool. Good work.
thefordmccord is offline   Reply With Quote
Old 01-01-2006, 08:19 PM   #3
slugzracing's Avatar
How wide are the axles? I have not seen them before and they look perfect for a project.
The truck looks like fun!
slugzracing is offline   Reply With Quote
Old 01-01-2006, 09:02 PM   #4
Thank you the axles are of origin, I just cut the interior of the rims, what to create this illusion of width
Old 01-02-2006, 03:06 AM   #5
crawl rookie's Avatar
wtf this is the nicest vmg i ever seen its getting harder and harder to make a better one (im making a laser cutted chassis mail me for some pics of the cad design)
congrats to you u did an exelent job there ROck the pieces out of it
greeets from holland
crawl rookie is offline   Reply With Quote
Old 01-02-2006, 09:07 AM   #6
Cool truck man! thats the best VMG I've seen!
Later,
Jak
JakeDaSnake is offline   Reply With Quote
Old 01-02-2006, 11:34 AM   #7
crawl rookie, I'm sorry but I don't understand all
thank you for your comments
Old 01-02-2006, 11:39 AM   #8
TEAM MODERATOR
EeePee's Avatar
Very nice truck!
EeePee is offline   Reply With Quote
Old 01-02-2006, 05:33 PM   #9
He said yours is the best. He's making one as well. His chassis is being cut by laser. If you want the drawing (CAD) email him for the drawing.
That's a real good job there. Truck looks solid and fun!
Plays_with_Toys is offline   Reply With Quote
Old 01-02-2006, 05:50 PM   #10
Ok! Thank you very much Plays_with_Toys
Old 02-03-2007, 05:45 PM   #11
Salut Nico 14
Scarfesse is offline   Reply With Quote
Old 02-03-2007, 05:47 PM   #12
rien a dire a part qu 'il est bien cool ton bison
encore du beau boulot
Old 02-03-2007, 10:02 PM   #13
K_B
The axles are about 4", hub to hub. These little rigs are a blast. They're quite under-appreciated I have just as much fun with my little VMG as I do with my 2.2s. And they're pretty stout too.
K_B is offline   Reply With Quote
Old 02-03-2007, 10:08 PM   #14
cleanest vmg ive seen yet good job
and ygpm
smokinubyrc is offline   Reply With Quote
Old 02-04-2007, 01:25 AM   #15
rig looks sweet
just curios why is this in the tlt forum
supercrawlerfreak is offline   Reply With Quote
Old 02-04-2007, 07:40 AM   #16
Default Vmg
I just started building one of these,www.one18th.com has a bunch of them and none of them even come close to this.You have definately built one of the best mini crawlers I have seen,congradulations. I forgot to ask,where did you get those blue steering knuckles?
red jim is offline   Reply With Quote
Old 02-04-2007, 09:55 AM   #17
the blue steering knuckles comme from to Dinball (rcmart.com)
