03-16-2006, 12:35 AM | #121 | |
Rock Crawler Join Date: Nov 2005 Location: dallas
03-16-2006, 03:38 AM | #122 | |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
03-16-2006, 07:32 PM | #123 |
Quarry Creeper Join Date: Aug 2005 Location: Jefferson City
ME TOO!!!! I may not get it done in time for our first comp, but I WILL get it done!
03-17-2006, 12:38 AM | #124 |
Quarry Creeper Join Date: Oct 2005 Location: SoCal
Great Rig and Video. Front dig mod is AWESOME That mod alone make's me want to build a shafty |
03-17-2006, 12:06 PM | #125 |
Rock Crawler Join Date: Nov 2004 Location: Roseville
Finally finished all the pieces that I needed for my dig setup. Here's some pics. This is just a general picture of it. It also shows the female shaft that is free to spin. This is a picture of the rear and the female shaft that acts as the brake. |
03-17-2006, 01:36 PM | #126 | |
03-17-2006, 02:37 PM | #127 | |
03-17-2006, 02:42 PM | #128 |
Looks very clean, let see it in youre crawler |
03-18-2006, 02:41 AM | #129 |
Yeah what he ^^^^^^^^ said! |
03-18-2006, 07:59 AM | #130 |
Quarry Creeper Join Date: Aug 2005 Location: logan
| Hey snowkd make your own thread on your build up of front dig!! Im interested to see how you do it. Im working on my own as I speak. |
03-18-2006, 09:46 AM | #131 |
If it holds up once I get it setup, then I'll make my own thread.
03-20-2006, 12:14 AM | #132 |
Did you get it installed SNOWKD? Let's see the pics......
03-20-2006, 12:49 AM | #133 | |
The other day i did the diggs mod to a sw2 crawler with max shafts, mounted the servo on the rear axle and turned the linkage around due to the motor on the left side of the chassis i think this style should work on almost any chassis setup. Pics of this style should be up in a few days i hope | |
03-20-2006, 10:11 AM | #134 |
I don't get my axle cases until later today or tommorow. So I won't be able to get my truck back together until then.
03-20-2006, 11:16 PM | #135 |
How bout you MINI you got pics of that SW2 crawler yet? |
03-23-2006, 12:42 AM | #136 |
Ok so I made a list of parts that I think I need to get this done.... 2 male driveline ends 1 female driveline end 1 piece of rod "inside male driveline ends" or all thread a variety of shock spacers some JB weld some CA glue some small screws and some sort of material to conect the shock spacer to the brake.....small metal chanel or something. Anything else I might need.......please feel free to let me know. |
03-23-2006, 04:35 PM | #137 |
A few more things i use .125x.250 .020wall brass to connect the slipper to the brake then use the dremel to cut a slot in it 440 allthread and nuts for the lever a max shock end for the lever pivot .045 machine screws micro drill bits and a pin vise i use the metal ring in the tlt kit to clamp the max shock spacer around the driveline while the glue drys |
03-24-2006, 01:27 PM | #138 | |
03-24-2006, 01:31 PM | #139 | |
03-24-2006, 11:40 PM | #140 |
Heres a few pics of front diggs setup on benders sw2 chassis with max shafts, the dig linkage had to go on the same side as the motor to clear the 4-link the servo is on the axle. This style should work on any style chassis |
